Gunson colortune
chuck1006
Hi,
Can the 14mm colortune be used on my 100-6 as is or do I need the long reach adapter?
thanks,
chuck
I haven't looked at them in a while, but the two Colortunes I bought many years ago came with a terminal extension and a long--about 6"--tube with a 'mirror' on the end (the 'mirror' is just shiny plastic). You need these so you can see the changes to the flame when you're adjusting the mixture on the other side of the engine.
C
chuck1006
Thanks Bob but the extension I was asking about was for the plug end that threads into the block. Does the standard one that comes with it show the spark well enough to tune? The extension is to get the spark deepen in the chamber.
regards
John Turney
I don't use the extension on my 100-6. I have the later head, not the gallery head. Which head do you have?
B TR6 Gunson Colortune Triumph 4
tahoe healey Gunson colortune follow-up Austin Healey 17
tahoe healey Gunson Colortune Austin Healey 14
tahoe healey Gunson Colortune Restoration & Tools 7
M Proper use of the Gunson Colortune Triumph 41
Moose33 Gunson's Colortune - Anyone used 'em? MG 4
6 Gunson Eesibleed Spridgets 3
T Gunson's "Colourtune" is the coolest thing ever Triumph 29
T Gunson Eezibleed Triumph 3
Patton Gunson Clikadjust - Timesaver or Timewaster Restoration & Tools 8
wangdango Colortune for HD8 Carbs? Austin Healey 55
R Colortune test plugs Triumph 3
M Colortune question Triumph 12
M colortune plug. Triumph 2
Gundy Colortune cleaning fluid Restoration & Tools 2
livinginthepast Colortune: Your opinions... Spridgets 8
CraigLandrum Colortune vs Old School carb mixture adjustment Triumph 17
healeyboz gunsons colortune Spridgets 14
B Colortune?? Spridgets 20
R ColorTune and Exhaust Gas Analyzer MG 6
A ColorTune MG 2
A ColorTune MG 3
RSMTR8 Wedge TR8 Colortune Triumph 8
J Colortune usefulness? Triumph 10
Rob_T Colortune? Restoration & Tools 6
jsneddon Interesting Carb Tuning with Colortune article Triumph 6
R Colortune MG 4
C Colortune carb tuning Austin Healey 2
J Rough Idle-Colortune-weak spark? MG 9
Bret Gastester & Colortune revisited – A status report Restoration & Tools 1
Bret Tree Huggers Vs. LBC Lovers. [was: Gastester/Colortune] Restoration & Tools 37
Bret Gastester vs. Colortune debate MG 0
Bret Gastester vs. Colortune the debate. Restoration & Tools 23
