getting someone to install my rockers and floors
jackag91
If I decided to go the route of having someone install my rockers (inner and outer) and floorboards, how much would I be looking at spending?
I think this might fall into the "worth the money, to get it done right" category.
toysrrus
Hi There jakag91;
I`ve never had it done but a friend of mine did his own & swore He would "Never, Ever" do it by Himself again!
It`ll probably be Big $$$ but I`m sure Well worth the $$$:
Have Fun Shopping;
Regards, Russ /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
PS: I guess I`m going to have to change My Avatar soon!
J
jackag91
Yeah that was kind of my thought. I might be able to do it, but then again I don't think it would be good place to scrimp and it will probably be a much bigger pain that I would want to deal with.
G
Re: getting someone to install my rockers and floo
Remember, you are basically cutting your car in half when you take out the floorboards and the rockers. Make certain that you properly brace the car together at the door openings, something you can do yourself with some welding equipment. Cutting out rockers may expose other rust damage. Be prepared for the worse. I changed out my floorboards (90%) without repainting the car. Wasn't that bad, wish I had more work area. Are you gonna leave the sills in place?
IanF
From what I've read about this job (quite a bit since Volvo 1800's suffer badly from this condition) is that while it's not terribly hard to do, it needs to be done carefully and in stages. In other words, don't cut out and replace everything at once, but so as to keep as much of the body rigidity as possible while each part is replaced. Keep the doors installed in order to check alignment. On the 1800, the general idea isto repalce the sill first, then the floors because there's a near 100% chance some of the subframe members need replacing as well, which are welded to the inner sill.
I had planned on doing this job on my 1800ES, but time, space, money and general desire have sine convinced me to move on to other things. /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
T
Tinster
Hey Ian-
I don't know about the rocker panels, but the floors are
something you can do yourself. Several methods have been
demonstrated here on the forum. I know almost nothing
about auto mechanics and even less about body work.
I replace a gaping hole in my floor with good, strong
results. It took me three weeks but was well worth the
effort. Saved me well over $1,000.
IanF
<sigh...>
I wish the floors in the Volvo looked as good as what you started with... /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
T
Tinster
Ah Ian, that a bummer.
Could you post a photo(s)
regards,
d
IanF
I'll what I can dig up... the car I have the most photos of I have since sold... the even rustier car I still have still has it's interior and therefore doesn't photograph as well.
BIBBER
just a suggestion...I have a local MOM and POP muffler shop here in town and they will do odd jobs for me at welding...they even do the work right while I'm there to watch (makes sure it's done the way I want it). It's worth a call if you have any around...they have the lifts and cutting/welding equipment...know how to make strong seams and they're always looking to make a buck and usually negotiate...
J
jackag91
I will post pictures of what i have to work with this weekend. Both rockers are shot. The floors have nice holes in them.
I was just kind of hoping for a ballpark. Am I looking at $1000 for labor? $500? $2000?
TR6oldtimer
IMHO, if you do all the disassembly work, and if you can find someone who has done this before, then it's probably a 32 hour job, else it's easily 40 or more hours.
So at $50 per hour you are looking at $1600-$2000+
Jon80spit
Member
I would do it yourself. Wasn't that hard on my 80 spit. Most of the rocker replacement can be done with a spot welder. Got a cheep one at Harbor Freight. Instant weld gratification!
The floor needs a gas, mig or tig welder. The cost to have it done would probably be more than a welding outfit. I made my floorboards, but would buy new ones if I did it again. The above comments are great. Keep the doors on and align the doors and body. Then weld in braces. Another thing I would do next time is to use weld-through primer where the metal touches and regular epoxy primer every where else. These cars rust from the inside out!
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
