Trying to get the car tuned... I have two questions:
1. What octane gas would I use w/lead substitute (original 1275 head)
2. Trying to get my carbs tuned... when adjusting the jets, after you turn the adjusting nuts two full turns, I have to turn an additional 15 or so to get the mixture rich enough. Is this normal? Mind you this is after I set the timing to 10 degrees @ 1000 rpms.
BTW: New plugs, wires, pertronix ignition, flamethrower coil...
Thanks
Tony
Thanks
Tony
