Fulcrum pin reassembly
Bob73RWA
Member
When reassemling the fulcrum pin does the large cork ring or the small cork ring go towards the front of the car? Thanks for the help?
ChrisS
The large (24) goes towards the front and the small goes towords the rear (25). Notice the position of the steering arm (31) in the diagram for orientation.
See pages 2 and 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
W Frozen fulcrum pin Spridgets 7
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
M_Pied_Lourd TR2/3/3A Fulcrum Pin Triumph 4
R fulcrum pin loosen Austin Healey 9
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
kurts100 Thread size on Fulcrum Pin Spridgets 7
bwm1974 Lower inner fulcrum pin seeking thoughts & advice Spridgets 1
I Bugeye fulcrum pin the sprinpan help Spridgets 4
K TR2/3/3A Advice on relocating TR3 chassis fulcrum pin.... Triumph 1
jhorton3 Blasted Fulcrum Cotter Pin! Spridgets 3
mrsprite lower fulcrum pin question Spridgets 1
jhorton3 Fulcrum Cotter Pin Spridgets 8
apbos Fulcrum pin thread size. Spridgets 7
WALTER replacing fulcrum pin Spridgets 6
fad64b Upper Fulcrum Pin Triumph 16
T Fulcrum pin orientation? Triumph 10
1 Fulcrum Pin Removal Spridgets 5
R Fulcrum Pin float Austin Healey 2
Gray_Cat Separating Fulcrum Pin from King Pin Spridgets 9
mcguijo TR2/3/3A upper fulcrum pin TR3 suspension Triumph 5
J Removing top fulcrum pin on front suspension. Austin Healey 2
SilentUnicorn fulcrum pin wear MG 9
J sprite A arm fulcrum pin [outer] Austin Healey 2
R TR6 Front suspension fulcrum pins Triumph 6
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
D 62 tri-carb upper fulcrum pins Austin Healey 4
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
S TR4/4A Reversing upper fulcrum link Triumph 3
H TR4/4A Worn Fulcrum pins Triumph 5
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
J TR2/3/3A TR3 - Lower Fulcrum thread size Triumph 4
T TR6 TR4a vs TR6 fulcrum pins [was TR4a shims] Triumph 31
M Lower Suspension Fulcrum Austin Healey 5
Jim_Gruber Bushings for Fulcrum Pins Spridgets 11
Jim_Gruber Removing Fulcrum Pins Spridgets 26
Jim_Gruber Replacing Fulcrum Pins and Bushings Spridgets 0
T Mixing one and two post fulcrum brackets Triumph 3
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
v8mgbal fulcrum nut torque Spridgets 5
K Bent trunnion fulcrum Triumph 21
swift6 Adjustable Upper Fulcrum pins! Triumph 9
B A- Arm - Fulcrum Grease fitting Spridgets 10
6 Inner Fulcrum Torque Spridgets 8
