Blasted Fulcrum Cotter Pin!
jhorton3
Major swear words given to the fulcrum cotter pins! I've used a file and a belt sander to try and whittle it down, but I'm no where close to having it drop down far enough to put the nut on the threads. Has anyone ever been able to use one out of the box without modification?
I never had trouble getting them to fit, but I've heard of plenty of people that have.
jhorton3
jhorton3
The right side pin is now ruined. I took too much off, so now I get to order a new one. Left side went right in without any modifications or problem.
HAN8L1965
I found that it wasn't so much the new pin as the hole in the bottom of the king pin. I found that the grinder set that fits the dremel which is made to sharpen chain saws fits in that hole very nicely and cleans it up enough to slide the pin in. Be careful as you will find it only takes about one pass. You can get this at Home Depot for a couple of bucks.
Mark
JimLaney How to treat media blasted steel Spridgets 3
healeyboz blasted fuel gauge Spridgets 46
jackq Blasted weather!!! MG 1
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
W Frozen fulcrum pin Spridgets 7
R TR6 Front suspension fulcrum pins Triumph 6
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
D 62 tri-carb upper fulcrum pins Austin Healey 4
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
S TR4/4A Reversing upper fulcrum link Triumph 3
M_Pied_Lourd TR2/3/3A Fulcrum Pin Triumph 4
H TR4/4A Worn Fulcrum pins Triumph 5
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
R fulcrum pin loosen Austin Healey 9
J TR2/3/3A TR3 - Lower Fulcrum thread size Triumph 4
T TR6 TR4a vs TR6 fulcrum pins [was TR4a shims] Triumph 31
M Lower Suspension Fulcrum Austin Healey 5
Jim_Gruber Bushings for Fulcrum Pins Spridgets 11
Jim_Gruber Removing Fulcrum Pins Spridgets 26
Jim_Gruber Replacing Fulcrum Pins and Bushings Spridgets 0
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
kurts100 Thread size on Fulcrum Pin Spridgets 7
T Mixing one and two post fulcrum brackets Triumph 3
bwm1974 Lower inner fulcrum pin seeking thoughts & advice Spridgets 1
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
v8mgbal fulcrum nut torque Spridgets 5
I Bugeye fulcrum pin the sprinpan help Spridgets 4
K TR2/3/3A Advice on relocating TR3 chassis fulcrum pin.... Triumph 1
mrsprite lower fulcrum pin question Spridgets 1
jhorton3 Fulcrum Cotter Pin Spridgets 8
K Bent trunnion fulcrum Triumph 21
swift6 Adjustable Upper Fulcrum pins! Triumph 9
apbos Fulcrum pin thread size. Spridgets 7
WALTER replacing fulcrum pin Spridgets 6
fad64b Upper Fulcrum Pin Triumph 16
T Fulcrum pin orientation? Triumph 10
B A- Arm - Fulcrum Grease fitting Spridgets 10
6 Inner Fulcrum Torque Spridgets 8
PeterK TR2/3/3A TR3A upper fulcrum bushings Triumph 12
J Fulcrum bolt won't come out! MG 4
J Fulcrum bolt won't come out! Spridgets 13
B Fulcrum pin reassembly Spridgets 2
1 Fulcrum Pin Removal Spridgets 5
