Does anyone know how the fuel tank venting is supposed to work?
I know about the small separation tank and the pipe to the charcoal cannister. The problem I'm having is pressure is building in the fuel tank and seems to be forcing fuel thru the gas lines into the Carbs and they are leaking from the float chambers when the car is parked. When I open the gas cap, the pressure releases with a noisy whoosh. I tried blowing air thru the separation tank line to the charcoal cannister but it appears clogged. Does this line need to be open to allow tank venting? This is on a 72 TR-6. Thanks for any information.
