dklawson
Vinegar is used to remove rust and scale, not the "gunk" formed as a fuel varnish/sludge at the bottom of the tank. Same with CLR. Both are acids.
If you want to remove the sludge, use a strong caustic cleaner like the ZEP Industrial Degreaser available at Home Depot and other places. Wear gloves, slosh it around frequently, allow it a day or more to work, then rinse with water. If you want to try the acid cleaners, do that AFTER the caustic. Acids will not remove the fuel deposits and gums.
