Fuel or Spark Issue?
spineguru
I have gone back through the Search engine and I am still having trouble determining the fastest and easiest way to distinguish between a fuel startvation issue and an electrical issue.
I am pretty inexperineced with working on TR's (I prefer the driving experience vs. the mechanic experience), so bear with me as a describe the situation. You may recall recently that I had complained of my 61 TR3A running rough. Well, it finally died. Let me describe it.
For a while it was running as if it was being starved of fuel or that it might be misfiring (I find it hard to tell the difference). Recently while I was driving, it really got rough (jumping and jerking quite a bit - felt like I was running out of gas, although it is full), so I turned around to head home. It finally died. I got it to start again, went about a quarter mile and it died for good. Had to get it towed home (a measily mile - yea AAA!).
Current symptoms are that it will just crank, but will not fire. I would think electrical, but I find it weird that it died on me, then I was able to start it, then it died again. Electrical things (in my mind) either work or they don't. Fuel / mechanical things can "sort of" work as they go from the working to failure modes.
Things worth noting. It does smell like gas after I crank it a while. The fuel filter does have gas in it. It looks pretty clear to me. The choke appears to be working, at least on the surface the mechanism seems to be doing what it should. the car is negative ground. My coil has + and 1 on it and the - goes to the points (which I think is correct). Nothing "looks" wrong in the distributor cap (we will hook up timing lights, dwell meters, check resistances and voltages later today).
Anyway, long story short, I have a neighbor who is willing to help, but I want to try to eliminate things as fast as possible. If this was your situation, what would you check, how would you do it, and in what order?
A huge thanks in advance for your help.
Bryan
Bugeye58
Bryan, if you smell gas and it won't start, it most likely is an ignition problem.
Pull a wire from a plug, hold it about 1/4" away from a good ground, and crank the engine. You should have a bright blue spark jump the gap.
That would be my initial test, anyway.
Make sure the points haven't closed up, as they often do.
Keep us posted, and we'll have you back on the road in no time.
Jeff
T
Tinster
Bryan,
when you pull that spark plug after a non-start,
check it to see if there is gasoline on the tip.
Then follow Jeff's advice. If you have a spark make
sure it is a good strong, blue spark.
My car breaks a lot and will not start many times
from blown up coils. I get a weak, dim spark when
my coil needs to be replaced.
So look for a strong, blue spark. A dim spark could
be a bad coil.
How long has your fuel filter been on the car?
They are cheap. Couldn't hurt to replace it.
best of luck
d
S
spineguru
Just about to head out and work on it. Just another FYI. The car was sitting for quite a while until about a year ago. When I got it running again, we did drain and inspect the tank. loked good. We also blew out the lines and replaced the fuel filter. I'll let you know if I get a spark. If the coil is bad, can it go bad "over time" or does it just die? As I said the car was running poorly on and off before it untilmately died. Could taht still be a coil. If I do not get a spark, how do I distinguish whether it is the coil or something in the distributor. I assume I can measure resistance or voltage across the coil. Correct? What should me readings be?
Thanks.
KVH
I'm a trial and error guy with (maybe) too many predilections.
Someone on this Board recently solved problems by installing a new condenser in the distributor. It first goes without saying that before you do anything with a rough running TR, you make sure you have good points, condenser, the right point gap, and accurate static timing.
So, check that first.
Then, with the key on, make sure you're getting current to the coil and from there to the distributor. Like others have said, a good test is to have someone crank the engine while you're holding a plug wire a short distance from a ground. See if you're getting spark. Make sure you're in neutral and you don't start the car up!!
Because you said the car runs and starts, or vice versa, two things immediately come to mind. Your fuel is obstructed or you're losing spark while you drive. The latter in my opinion is rare, but I suppose it could be a bad wire or connection, or bad coil. For me, over the years, it was almost always the fuel--dirt, junk in the tank, etc. Also, I'd rather run rich than lean, so be sure your mixture is right and that you're not starving the engine of fuel.
I don't like recalling this, but after many experiences with a stalled '62 TR, I finally disconnected the gas line where is goes "into" the fuel pump from the tank. It dribbled. It should have flowed strong. Problem: a nice piece of scrap wood furring someone dropped into my tank years earlier.
Good luck, and now that I've rambled, let us know what the real problem was!
KVH
Meant to say: Don't underestimate the importance of a good distributor cap, rotor and plug wires. I've been stuck because of those, too. It's embarrassing to be towed to the shop just to replace a simple distributor cap.
S
spineguru
I just went out to tackle this thing and thought "why don't I just give it another try before I do anything", and "Voila" it started. So I thought, "What the heck?!?!" The only thing worse than a broken car is an INTERMITTENT broken car. It is always a problem to make the problem reoccur.
Well, I guess I got "lucky", while I was revving the engine (it had already got to running temperature, and I had driven around my cul-de-sac a bit) it died again. I restarted it and it died almost immediately. Now it is back to just cranking. The fuel filter is EMPTY and fuel IS NOT flowing into the filter when I crank. Just the occasional dribble.
OK, so here is my latest issue, since it did start, I am thinking clog in the line. The glass bowl in front of the fuel pump is FULL of gas, so it seems to me it is the pump or a clog in the pump or in the line after the pump. I guess the pump could be bad, but wouldn't that NOT be an intermittent issue? Wouldn't it just either work or not work?
I guess I can check the flow of the fuel prior to the pump by removing the line and seeing if it just flows out. If it doesn't, there is a clog. The major pain in the rump is that I filled the gas tank the DAY it originally died. It is completely full. Annoying. I guess I could clamp off the line once I see that it is flowing.
Any thoughts based on this rambling information?
Bugeye58
Well, Bryan, you can start by disconnecting the line from the tank to the pump and see what kind of flow you have. If that looks good, disconnect the pump to carb line, remove the coil wire at the coil, and crank the engine to see what kind of fuel delivery you get.
Sometimes a gentle shot of air in the line from the pump back to the tank can dislodge any blockage, but that doesn't cure the problem. If there is a blockage in that line, and you blow it out, chances are it will find a way to return.
Have a fire extinguisher handy when you do this, please.
Jeff
mike crane
Bryan
I had a similar problem with my TR6 and we had a TR4 come to a halt on a road trip last summer. After a lot of head scratching and checking for spark and gas flow we found in both cases that a falwty (take note Basil)
rotor was the cause. On mine it was all the more baffling because it was a nearly new rotor (Lucas) and showed no outward signs of being defective. It is still running on the used replacement after a 1500 mile tour. I am running with a Pertronix so I knew that it was not points or condensor related. My first clue was when I pulled the pertronix and reinstalled the points and it still wouldn't run. When the TR4 stalled on our tour the first thing we did was install a replacement rotor and all was well the rest of the trip. Your results may vary, but try it.
Mike Crane '71 TR6
Harry_Ward
Some additional stuff,
There's a brass screen at the top of that glass bowl on your fuel pump you may want to clean first, then replace, then check fuel pump for proper operation as Bugeye suggests. The screen is in the upper part of the pump bowl housing and may stay in the housing when you drop the bowl so you may have to prise it out carefully as to not distort. You can clamp off the rubber hose of the fuel line with vise grips or a hemostat if your shut off is not there or inoperable. Use something like a rag to protect the hose from the serrated jaws of the vise grips though. Do not reuse the original cork gasket for the glass bowl it will probably leak. You will need to buy a new one. Also check the vent line from the gas tank for blockage from mud wasps. These pumps don't gush out fuel either they just seem to spurt so if it's spurting it's working.
Jim Lee
Bryan,
In your first posting you said that there was fuel in the filter "The fuel filter does have gas in it.". Now there is no fuel getting to the filter but you fuel pump glass is full? I assume that your filter is between your fuel pump and carbs. If the tank is full I think you are almost home with one of two problems. A flaky fuel pump or an obstruction that is on the move between your fuel pump and carbs. I have an electric fuel pump on my tr3a that I got at the local auto parts store for about $20. Less than a carton of cigarettes in North Carolina. I am pretty sure that your fuel pump (especially if original) could be providing enough pressure occasionally and for short periods of time if you had a dying diagphram or bad seal in the pump. My approach to trouble shooting the mechanical fuel pump would be to pick up a 3-5 lb pressure 'Facet' pump at your local auto store and by pass the original pump as the quickest and easiest way to find out if the pump is the problem. Do you know if it is original? Does it have a hand primer on it?
You would probably first want to do the easiest and cheapest
troubleshooting by detaching the fuel line from the pump to the carbs and blowing it out. If that makes no difference than I would pick up an electric pump even if you just use it for troubleshooting...to find out if your pump is bad and
then get another semi-original or rebuild your pump. All you have to lose is about 20 bucks and even if you decide to
go back to the original you will have bought yourself as much time as you want to rebuild or replace. I had an original pump which went bad and it was very inconsistent
until I replaced it. My theory being that under some conditions it was able to provide enough oomph to get the gas to the carbs, and sometimes it was not. I did the electric pump thing and never went back.
Good luck and be sure to tell us how you fix it.
Thanks,
Jim Lee
S
spineguru
Jim:
You are right, I am getting close. I checked the line between the pump and the filter and all is well. Perfectly clear. So I am thinking the pump is bad.
HOWEVER, one new wrinkle. While I was removing the fuel line from the pump to the filter, I noticed that the vacuum unit attached to the distributor was cracked. Actually when I noticed it, I jostled it a bit and it broke further (typical Bryan Monroe move to further destroy something). It looks like the PO (I gotta be careful here, because the PO is my Dad!) rigged it with epoxy or something. The thing clearly is not pulling any sort of vacuum anymore.
Two questions...
1) Could this be part of the problem or did I just create a new issue?
2) How does the vacuum unit attach to the distributor? Mine is so rigged I cannot tell how is supposed to go. The Moss diagram looks like it just slips inside the distributor, but how does it stay in place?
So now I have 2 problems. The vacuum unit and (potentially) the fuel pump.
Gotta love these LBC's!
KVH
Let's assume the carb jets are set right and the pistons fall freely when you lift them. And let's assume no blockage inside the fuel bowls.
I'll now pose another idea for you to check. Hope it's not a waste of time. I'll enjoy the typing. Here we go:
The fuel pump bolts to the engine with a manual "flipper" that goes into the block. There's a pin in the pump housing that holds the flipper in place, and that pin can often dislodge and allow the flipper to dangle inside the block. That would mean no gas, no pump operation.
This is not the "red-herring" issue some might think it is. It happens with some real frequency. Take a hard look at the back part of your pump, with a good light, and examine the pin to see if it's protruding or whether it's squarely in the pump housing, equal distant on each side from the exterior of the housing.
If there's a problem, take the pump off and fix it. I did this just 6 months ago. Didn't take all that long. The flipper was literally hanging on the dislodged pin. That pin fits in with mere pressure--or by what might be called a "peening" of the pin ends.
Anyway, maybe irrelevant.
spooch22
I had alot of the same problems with my car and like kentvillehound said,the new condensor and point gap adjustment has the car running absolutely beutiful. If you haven't already tried this I would be very interested in seeing the result.
Jim Lee
Hi Bryan,
You wrote:
"While I was removing the fuel line from the pump to the filter, I noticed that the vacuum unit attached to the distributor was cracked. Actually when I noticed it, I jostled it a bit and it broke further"
The vacuum on my previous distributor was not working for I don't know how long. It is possible that it could make a difference in how the car runs but it is not going to stop the car from running. I don't have any experience trouble shooting a bad mechanical pump but if there is any way to see a problem WITHOUT having to remove it, like checking for both ends of the pin, you should definitely do it. The only thing that I know of is to check the pressure either by detaching the fuel line from the carbs in a safe manner and actually observing the flow or sticking a pressure gauge just before the carb. But the pressure gauge would probably
cost as much or more as the electric fuel pump at your local
auto store. You could attach some fuel line from the downstream side or the pump and into a proper receptacle and
see what kind of pressure/flow you have. It is not very much but if you get nothing or very little it should be pretty obvious. That would also give you the chance to blow
out the pump to carb line which is not going to hurt even if there is not blockage.
On my 59 TR3A the vacuum line to the distributor is a very small metal pipe like a mini brake line that attaches under the manifold and at the vacuum pod on the distributoe with a
threaded air tight fitting. I don't see any reason why you could not just splice the broken pipe to the distributor using a small piece of hose as long as it is air tight. You
will have a vacuum leak in your manifold if you do not plug it or reattach it. I understand that many aftermarket and rebuilt distributors do not have the threaded fitting.
Thanks,
Jim Lee
YankeeTR
Blow compressed air thru the line from the fuel pump back to the tank.
Check all flexible fuel lines...they get soft and collapse blocking fuel flow.
Check all fuel filters...some PO may have installed an in-line filter that may be plugged.
Hook up an "Okie" gas tank and see if the car runs with that...that will isolate the fuel supply and if the car runs OK then you have a blocked fuel supply line.
Oh yeah..an Okie gas tank is a temporary gas can hanging from your hood...hook it up to the inlet side of your fuel pump or the inlet side of your carbs...
KVH
Before you go too far, do what YankeeTR said. Blow that line back to the tank. Use compressed air. I'd do that before worrying about new pumps and alternative setups.
Careful. The fuel might really start to flow.
S
spineguru
Even if the bowl just prior to the pump is full? Seems that if there was a clog, the glass bowl would not be full? Am I wrong?
Also, maybe a dumb question, but what the heck. When I take off the fuel line prior to the pump, I will clamp the rubber part of the line with vice grips (I will be careful not to damage the line). If i release the vice grips and fuel flows, can I assume it isn't blocked? If not, how do I blow air into it while fuel is flowing? If you say "drain the tank", that is a huge pain. I just filled the car up the day it broke down. It is completely full!
Thanks for bearing with me on this stuff.
bugedd Spark or Fuel? Spridgets 8
texas_bugeye Spark plugs Heat range Ethl blended fuel Spridgets 6
C Fuel and Spark but still not starting Triumph 7
G Fuel Spark...still won't start ? Spridgets 17
Monark192 Got spark, got compression, got fuel..... MG 19
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
