Fuel gauge question
bighealeysource
Bronze
Got a used Smiths "hanging needle" gauge to put in my 100M and in great condition. Before sending it to Nissonger for a check up or repair, quick question. When I hooked it up to my harness the needle would slowly swing up to 3/4 full regardless of which way the leads were hooked up. Problem is the tank was 1/4 full based on an existing gauge in a BN6 which is new and accurate as well as the old dependable measuring stick. IS there something else I can try to see if it is working correctly before shipping off to Nissonger ?
Thanks,
Mike
red57
Mike,
I wouldn't bother testing it. Just send it to Nissonger. I have sent them several 'dead' gages and they can rebuild and make them work like new. If they get a gage that is not repairable, they will let you know. The only time I have had difficulties was a gage with a broken needle and they didn't have a replacement needle - so I sent them another 'dead' gage and they swapped needles.
Dave
Swoz
Member
Mike,
Make sure the gauge case has a good ground connection, or it will not read properly.
The back of your fuel gauge should have a "B" and a "T" terminal. If you have an ohm meter you could measure the resistance from the "T" terminal to the case ground, which should give a reading of about 100 ohms. If you test from the "B" terminal to the "T" terminal you should read about 60 ohms. These readings would indicate that the two coils internal to the gauge are in fact good. The rest of the parts in the gauge are not likely to go bad. So, if your coils are good and your not missing any parts, Nissonger will basically clean (new chrome bezel, glass...etc) and calibrate your gauge. If one or more of the coils are defective, they can still repair it it, but it will cost a bit more......Tony
Keoke
:iagree: Dave I wouldn't bother testing it either. Just send it to Nissonger---Keoke--- :yesnod:
C MGA Fuel gauge question MG 8
S Fuel Gauge Question Austin Healey 8
N Fuel gauge question?? Spridgets 3
Marvin Gruber MGA Negative grd- fuel gauge question MG 18
T TR2/3/3A TR3A fuel gauge question Triumph 36
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
G Fuel Gauge - Sending Unit Question Austin Healey 20
W fuel gauge question Triumph 7
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
