fuel gauge question
wifegonnakillme
I'm down to the tinkering stage with my 3 -
My gauge does move around, I can fill it up and get a full reading, occasionally at or around half it reads half and sometimes, even though it is not empty, I get an empty reading - however it is not reliable and does not graduate smoothly from full to empty. Do you folks think that this is a problem with the float? I haven't observed it sinking below the level of the fuel, so I tend to think it is holding air. One possibility is that it is just not moving as freely as it should...
Wiring connections should be good with the new harness.
I could pull the tank (and eventually I will have to as there is a small leak at the top by the sender), but I would rather have a better idea of where to look before I take that on...
thoughts appreciated,
Kerry
NickMorgan
You can use a bit of hooked wire to move the float up and down through the filler opening. You can then watch the gauge, with the ignition on while the float is moved through its full range. Most likely it will be the sender unit that is faulty. It was on mine, but i only discovered after replacing the gauge!!
guzzul
I assume you have tried grounding the sender wire a couple of times to see how the gauge reacts. If it goes to full smoothly then the gauge is probably fine.
I'm not sure if the 3 uses a voltage stabilizer or not, but that is another source of problems. If your other gauges are working properly (notably temperature) then the stabilizer is probably ok.
You might check to make sure the fuel tank sender ground is not intermittent or corroded, which might cause variable results too.
If the problem is either the sender or the float you are going to have to pull the sender anyway.
MGTF1250Dave
Aloha Kerry,
The fuel gauge sending unit can be checked as Nick suggested. If you remove rear bulkhead panel you have clear access to the top of the tank. Guzzul lists the basic electrical test that I would recommend. If the gauge reacts well to those tests, the sending unit can be then be removed with out taking the tank out of the car or the added hassle of draining it. With the sending unit in hand you can easily move the float and see how the gauge reacts.
PSUTR3B
My guage is rather slow going from full to 1/2 but declines over fewer miles (ie. faster) from 1/2 toward empty. The last quarter can go in a fairly short distance. It certainly does not go down at a constant rate. From others I have talked to, this is not completely unusual. The empty reading when it is not could be a grounding issue.
Gary
BIBBER
Likewise I have not been able to rely on my fuel gauge...I elected to use the NOS version a stick....
philman
i had a problem with the fuel guage on my mgb-gt. guage was fine, when I replaced the sending unit i found the float was fouled by one of those silly springs that people put in the filler neck to prevent gas siphoning. sending units aren't usually very expensive or hard to replace. for peace of mind i replaced mine even after i fixed the problem.
C MGA Fuel gauge question MG 8
S Fuel Gauge Question Austin Healey 8
N Fuel gauge question?? Spridgets 3
Marvin Gruber MGA Negative grd- fuel gauge question MG 18
T TR2/3/3A TR3A fuel gauge question Triumph 36
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
bighealeysource Fuel gauge question Austin Healey 3
G Fuel Gauge - Sending Unit Question Austin Healey 20
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
