Front Seat Bases and Door Seals -- BJ7 -- Advice
BG 62AH
Guys, I really need a little advice on mounting my front seats, and some help with door seals.
On the seat frames, I am ready to install the carpet into the car. I am confused on the the order to install the steel strip and the wood spacer (that go under the seat runners), and if these items are installed on top of the carpet, or cut out recesses in the carpet.
With the door seals, I've seen some cars where the door seals run up the inside the B pillar, and then are capped at the top of the door opening. On other cars, I have seen the door seal material continue past the top of the door frame and then continue to run along the top of the rear inside panel (my car is a BJ7, so it has the recess for the folding top). I am unclear on which is correct.
I would really appreciate any thoughts or advice or pictures. Thank you very much for your help.
Bill
British_Recovery
Bronze
The door seal should run up and onto the panel covering the top recess where the springs are. It should end with part # 240-530 "CLIP-door seal end" in the Moss Motors catalog.
vette
Bill, I agree completely with DerekJ and Bob. I just wanted to add that I believe the best source for the door seals is McGreagor in Canada. His are the exact copy of originals and of unquestionable quality. I originally tried to fit other products from other sources and had unbelievable problems. Finally threw everything out and bought everything from McGreagor. My car is far from original but I would have run the furflex over the top edge of the inner panel if i knew it was the correct way at the time. But I cut it too short before I found out. My aluminum finisher panels were bent up, tore up, and painted black when I got the car. So I hammered them straight, stripped and sanded the paint, then clear coated them to try to make them do.
RAC68
Hi Bill,
As I understand and Derek stated, the rugs should be easily removable to allow any penetrating rain saturation to be dried outside of the car. I often wondered, and would appreciate knowing, why English cars of the era (created in a moist climate) were less weather protected then Italian cars (manufactured in a sunny climate).
The original rear rugs and pads (per the picture below) were slotted to allow them to extend under the seats and surround the runner. The packing wood and metal strips were installed to raise the seat runners off the metal floor to allow room for the rugs. Keep in mind that the slots are cut into the rear floor rugs and the front floor rugs terminate at the front of the seats. Snaps are installed on the back of the rugs with receivers installed into the metal floor and through the pads. The snaps keep the rugs in place and allow the rugs to be removed. Removal of the snap receivers is necessary to remove the floor rug padding, however, the amount of moisture penetrating the cabin was expected to be small enough to be held by the rug (a miscalculation in my opinion and experience).
Ray(64BJ8P1)
B
BG 62AH
I really appreciate all of this information, the pictures are great. Thank you all so much
RAC68 Front Seat-back Angle Austin Healey 15
wangdango BJ8 front seat redo? Austin Healey 8
DornTRoriginal TR2/3/3A Front Seat Reupholstery and Seat Heaters Triumph 4
Johnny AH BJ 7 front seat pans Austin Healey 0
L Front Seat Rails Installation Austin Healey 7
C front seat base Austin Healey 2
JamesWilson Front Coil Seat Dimensions? Triumph 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
