TR2/3/3A Front Brake Conversion
Redoakboo
I have just purchased a 1954 TR-2, that will need a full restoration. I am thinking of converting from drum to disks on the front. I did the same conversion on my 57 Thunderbird and it was not that bad a job.
Do any of the parts places sell a kit for this? or, do I have to find a salvage vehicle for parts?
Dick
Lou Metelko
Dick
I have a 54 TR2 with drums all around. Since 2003 we have put well over 40,000 miles on it and not once did I feel the drum brakes were inadequate. Stories to the contrary are old wives tales. Properly adjusted drums are fine!
Lou Metelko
Auburn, Indiana
54 TR2LD TS981L
CJD
The TR2 frame is missing mounting tabs for the disc brake hoses at the front. All the other parts are just a swap...but that swap includes all the lines, hoses, fittings and Master cylinder from the line into the rear hose forward. Swapping the master will also require you to swap the clutch master cylinder and slave cylinder for the disc cars too.
I’ve been driving my TR2 with drums. It does not pull, dart or complain at all. The car stops just as well in light to moderate braking with no difference I can tell from the discs, except it rolls freely after a stop instead of dragging like the disc cars do with the 5 way valve that holds pressure up front. In heavy stops the car takes more pedal pressure, but still stops evenly and locks the wheels together.
Why do you want to change to discs? It will devalue the car for minimal improvement in braking. I’d just buy a TR3A if you really want a car with discs.
R
Redoakboo
Thanks John,
I have a 57 TR-3 too. The engine has been upgraded substantially with 87 mm P&S, Isky cam , larger valves, titanium pushrods, aluminum flywheel and a set of headers. It has 11:1 compression so I run non-ethanol 93 octane.Brakes work great!
The 54 TR-2 I just purchased has been sitting in a conditioned garage for 30 years! I will be re-building the entire brake/clutch systems and will stick with the drums. I would love to find a set of Alfin drums, had them on my 55 TR-2.
Dick
CJD
Now the Alfin drums would be a cool upgrade to your TR2. They are from the same period and would add value to the package overall.
I Bug eye front disc brake conversion. Spridgets 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
M Front Big Brake Conversion Spridgets 20
M BN4 prob with disc brake conversion[front] Austin Healey 2
R front brake conversion Austin Healey 13
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
bighealeysource Front Brake Adjusters Austin Healey 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
bighealeysource Question on 100M front brake cylinder Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
John Turney TR6 Brake Line to Front Calipers Triumph 4
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
I Wanted Sprite front brake parts Spridgets Classified 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
T Assistance with Front Brake Lines Spridgets 3
doc50 Met front brake pistons Other British Cars 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
G Rover P3 Brake Lining - Front Rover / Land Rover 2
K TR2/3/3A Front disc brake squeal.... Triumph 4
L Front Brake 100/6 Austin Healey 1
R Help with BJ7 front brake line routing Austin Healey 6
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
A TR6 '73 tr6 passenger front brake dragging Triumph 2
F Front brake hose BJ8 Austin Healey 4
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
F front brake hose 67 BJ8 Austin Healey 4
M Front steel brake lines Spridgets 9
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
R BJ7 Front Brake disc hitting Austin Healey 12
P Bugeye front drum brake picture Spridgets 7
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
bigjones Front brake job - any advice? Spridgets 94
RJS TR4/4A Replacing front brake hoses Triumph 10
C question on the front brake lines for BJ8 Austin Healey 2
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
