Flex Fuel Line Leaking
Blonde Healey Girl
The flexible braided line from the fuel line to the carbs (BT-7) had a fine misting leak while under pressure. If you moved the line it would leak more. I replaced it today. Just wondering is there a rubber hose inside and is it possible that our 10% ethanol injected into our local fuel caused the rubber to fail. The faulty hose was installed 6 yrs. ago. (no telling how long it was on the shelf from the parts company).
Are there any other rubber fuel parts on the car that I should be watching?
Thanks!
roscoe
Yes, there is a rubber inner hose under the braided stainless. No telling what the composition is. In the aviation industry we have found that ethanol, under some conditions can cause swelling or decomposition of some fuel line material. I think that this is not a problem with modern compositions. I have a Sthil chain saw that works fine if I run aviation gas in it, but the fuel line lasts only a season if I use automotive fuel. However, six years is perhaps a reasonable life for a fuel ine that has been on the shelf for an unknown period of time.
HEALEYJAG
Ethanol will also increase your chances of vapor lock....which is why I prefer Sunoco gasoline which is free of ethanol here in ohio.
B
Blonde Healey Girl
What would Avgas 100LL do for a 3000?
It's $5.00 a gallon here at our local airport.
We have a 5hp tug and a airport use only 150cc Honda moped that runs solely on Avgas and they seem to do just fine.
roscoe
It sure wasn't 5 bucks a gallon when I managed to fall into about 300 gallons of free 100LL. I was going to run it in my airplane, but I managed to put that out of comission (long story), and in the meantime finished the 100 which I had been working on for a long time. I was delighted to run some lead through the motor I had just built. So the answer is, that it was sitting around, and it didn't cost me anything. In general, if it doesn't ping under load I'll run it. I will be sad when it is gone, it smells so mich nicer than the brew they sell as auto fuel.
zblu
I used to use avgas before, good stuff, think standard, then premium, then avgas, its really good stuff, just more lead in it and a higher octane reading, however over here it not allowed in your car on the road due to no road tax on it and its more flammable if thats the word for it
I believe avgas has a lower and more consistent vapor pressure (Reid Vapor Pressure or RVP) rating than autogas. Also, the VP of autogas is usually seasonally and regionally adjusted (higher VP in winter, lower in summer). So, a Healey running pure avgas in winter might be a little harder to start.
The lead in avgas won't hurt a Healey engine since there's no catalytic converter (yet ;), but a stock Healey engine shouldn't need 100 octane so a 50-50 mixture with premium autogas would be more economical. The lead in avgas should help protect your valves and seats, but running pure avgas in a relatively low-compression engine might result in lead fouling of the spark plugs, piston rings and/or valve stems/guides.
One other thing: I wouldn't run much if any avgas in an engine using full synthetic oil; synthetic oil does not scavenge lead well and this can lead to fouling of rings and/or valve guides. This is why Mobil AV1 was pulled from the market and there are still no full-synthetic oils used in light piston aircraft (that I know of, anyway, though there are several popular synthetic blends in use).
J thread count on the fuel line to flex line Austin Healey 9
jfarris For Sale FREE 83mm flex hone - item claimed Triumph Classifieds 1
W replace rigid master cylinder lines with flex. Spridgets 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
J TR4/4A Upper steering flex coupler Triumph 4
M TR4/4A Reducing rear chassis flex. Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 73mm Brush Research Flex Hone Triumph Classifieds 0
wangdango XKE clutch flex line/firewall? Jaguar 1
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
H larger flex fan Austin Healey 2
fpstude TR2/3/3A Flex Oil Line to Oil Pressure Gage Triumph 5
M_and_P A bit of flex British Motor Corp 5
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
J Front fender flex ??? Triumph 15
D Oil pressure gauge flex hose. Spridgets 29
F Chassis flex during panel replacement Austin Healey 7
I Bristle flex seal help please Spridgets 0
SkinnedKnuckles TR6 TR6 Steering Flex Coupling Triumph 7
G Texas Cooler Versus Flex Fan Austin Healey 20
livinginthepast 948 Fan flex? Spridgets 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
svtmikey Metalastic versus generic Roto-flex couplings Triumph 5
G Frame Flex Triumph 19
Atrus Flex brake line to rear axle Spridgets 2
N TR6 Installing Flex Coupling for steering TR6 Triumph 5
startech47 Flex fan on 1500 Spridgets 6
M XJ6 flwheel ring gear smaller than flex plate ring Jaguar 5
T TR6 tr6 body flex Triumph 3
B Progress Up-date - Shell "Anti-flex" Supports MG 7
T TR4/4A Flex Couplings [4a Steering] Triumph 10
T flex a form fiberglass leaf springs Triumph 2
T FLEX A FORM FIBERGLASS LEAF SPRINGS Racing 21
K Frame and Body flex ??? Triumph 9
G How much frame flex is normal? Triumph 8
G Flex Fan..... Triumph 2
T TR2/3/3A fuel pump oil leak Triumph 7
M MGB Fuel pump Banjo fittings MG 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 14
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
