TR5/TR250 250/6 replacing rear flex brake hose
TonyPanchot
Ok I am board and have the last of the parts to finish the brake system so I pulled the tyre and am still baffled as to the best way to replace the rear flex hoses, L and R
if I could just find a leprechaun to get in there :wall:
any thoughts are always appreciated and welcomed
kodanja
why are you having trouble removing them?
two wrenches should do the trick.....
Geo Hahn
I'll add, in case this is what is confusing you... you may have to start with the inner hose connection followed by the outer hose connection.
Then again I may be all wet as I do not have this car... just recall that on some cars the hose needs to be able to twist as you undo the end at the wheel.
Andrew Mace
Ideally, at least one of them should be a flare wrench, particularly on the male-end pipe fitting. Oh, and it can't hurt to spray a bit of a penetrant (PB Blaster, etc.) on that fitting if it's been there any great length of time. Corrosion can set in over time and the pipe twist apart rather than the coupling loosen. Same with the locknut on the hose where it goes through the bracket.
Worst case scenario is that a brief application of a propane torch flame on that male-end fitting can help free it up without hurting anything; been there, done that more than once!
TonyPanchot
TonyPanchot
There is no room in there
on the driver side there is a block mounted to frame the flex hose comes off and over to rear driver wheel
other side is a pipe over to left flex
so I guess I was asking if there was a special tool for the job?
bash
I remember this being a total pig of a job. As I recall, I took the 3 way piece off on the driver side, cleaned it up and attached the hose before reattaching it, which was a lot easier than the alternative. On the passenger side that isn't an option. I seem to remember twisting the hose (from the other end) while holding the retaining nut in place with an outstretched finger to get it most of the way in (not even finger tight - don't want to twist the hose too much and it still needs to turn), then twisting again to get it most of the way into the pipe union. A stubby spanner, a flare wrench and a lot of patience for the tightening.
Hope that makes sense
Cheers, and good luck
Alistair
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
V Wanted TR-250 in excellent condition Triumph Classifieds 14
T Wanted TR 250 Seats Triumph Classifieds 5
E TR6 measurements of a Snugtop hardtop for 250/6 Triumph 2
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
T TR5/TR250 250 Sway Bar Link Triumph 0
mrv8q TR5/TR250 Red 250 for Christmas morning! Triumph 10
T TR5/TR250 TR-250 Guages Triumph 4
T TR5/TR250 Amazing TR-250 Triumph 4
T TR5/TR250 TR-250 Production Numbers Triumph 1
T TR5/TR250 TR-250 Tire Size Triumph 6
M TR4/4A TR4A & 250 front bumper guards Triumph 5
Marvin Gruber TR5/TR250 TR 250 horns Triumph 3
D TR4/4A TR-250 seat covers on TR-4 seats Triumph 3
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Other British Cars 0
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. TVR 0
NutmegCT Off Topic Daimler V8/250 or Jaguar MkI/MkII wanted. Triumph 1
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Sunbeam (Rootes) 1
NutmegCT Daimlere V8/250 or Jaguar MkI/MkII wanted. Spridgets 7
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Rover / Land Rover 0
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. British Motor Corp 0
NutmegCT Off Topic Daimler V8/250 or Jaguar MkI/MkII wanted. MG 17
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Lotus 2
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted. Jaguar 6
NutmegCT Daimler V8/250 or Jaguar MkI/MkII wanted Austin Healey 0
NutmegCT Daimler 250? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
M TR6 TR-250 CC engine runs great, then nada, wait > 2 days, then runs great again, repeat Triumph 7
HerronScott TR4/4A TR 4/4A/250 Hard Top/Surrey Top on eBay Triumph 14
Nunyas John von Neumann's Ferrari 625/250 TRC Other Cars 0
Nunyas New Petrolicious vid: Ferrari 250 GTO Other Cars 2
tinman58 TR5/TR250 TR 250 Grill Triumph 14
tinman58 TR5/TR250 250 wheels [rims] Triumph 23
DNK TR4/4A TR4 & 5 owners and 250 Triumph 19
DMShuman TR5/TR250 TR-250 Vacuum advance module.... Triumph 5
tinman58 TR5/TR250 250 gettin there Triumph 4
C Daimler SP 250 - Pedal Rubber/Pads + other bits Other British Cars 6
tr6nitjulius TR6 TR6/250 & Healeys Drive 'em! Triumph 0
PatGalvin TR5/TR250 TR-250 Buyers Guide Triumph 12
NutmegCT 1971 Mercedes-Benz 250 Spotted 1
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
tinman58 TR5/TR250 TR 250 head? Triumph 4
tinman58 TR5/TR250 TR 250 "While I am there" Triumph 23
tinman58 TR5/TR250 Tr 250 A/C Triumph 9
EricG Tiger/Daimler SP 250 Comparison Test Sunbeam (Rootes) 1
glemon TR5/TR250 Lowering TR4A/250/6 in the front Triumph 13
TonyPanchot TR5/TR250 TR 250 Hub Cap Triumph 12
tr6nitjulius TR5/TR250 FYI: Ford Blue 250/6 Triumph 12
mrv8q TR5/TR250 TR 250 Silver Springs. MD Triumph 0
