Well I got her all together & bled and took her for a spin.
1 - Clutch engages really close to the floor.
What can it be? Does it need more bleeding.
2 - I need to step on the Brakes quite firmly to get her to stop. No pulling left & right but I need time to stop.
Can I improve this even after I rebuilt everything.
3 - Kinda bogs down as I work my way through the gears as if I am not running right. Holds it's own ok in the higher revs. Feels like I have a loss of power & it stutters a bit.
4 - Parking brake fully adjusted but does not hold 100%.
Can I improve this?
I noticed that the inside of my tailpipe is very sooty and it was not before.
Other than that I still have work to do. Tires are done as I am all over the road. Steering feels loose but it is very responsive. When I hit a bump the steering wheel moves left to right as if the rack is loose? I did not find a grease nipple on the rack but there is a small cover plate with two bolts down by the radiator. Is that where I fill it with oil?
No vibration at speed just when I hit a bump. After I get new tires (maybe wheels) I can see what else I need.
Can I improve this?
