Figure of 8 Gaskets for Wet Liner Engine?
karls59tr
Bronze
Did they come in different sizes of thickness and what was the stock size....015? Who supplies these if there are different sizes?
TomMull
I just went through this with a recent rebuild. As I recall, the standard gaskets mic out at .013 and that's all that's available from standard sources, Moss, TRF etc. I'm told Gasket Works https://www.headgasket.com/ will make custom sizes but have not contacted them personally. I also found that the only material available is steel. It is also possible to cut these from sheet copper with some relatively simple tools. I haven't done that either but can post a link with instructions as soon as I get to my home computer. Tom
Here's the link: https://www.tonydrews.com/uncle_jacks_engine_building_tips.htm#Fig8
TR3driver
Great Pumpkin - R.I.P
I can confirm that Mordy at GasketWorks can make them any size you want, for a price.
But I went a different route. Soldering a ring of 20 AWG "half hard" copper wire to the headgasket has worked well for me:
TR3driver
Oops, my bad. In case anyone else comes along and reads this, it was actually 26 AWG bare copper, not 20.
MDCanaday
The main issue with the liner fig8 seals is make sure NOT to use aluminum seals they dont last over time.Captured between two pieces of iron is no place for such tender metal.Galvanic corrosion will eat it in 7 or 8 years.
MD(mad dog)
KVH
Mad Dog is right. On my rebuild my old figure 8s were of aluminum, and they were corroded, broken and ugly. They were also too thin.
The copper ones are the way to go. They'll also help with the required protrusion above the block.
P TR2/3/3A Figure 8 gaskets at bottom of liners Triumph 4
S TR2/3/3A Figure 8 gaskets Triumph 17
KVH Revelation Re Those Figure 8 Sleeve Gaskets Triumph 8
KVH Figure 8 Gaskets Below the Sleeves Triumph 4
KVH Those Figure 8 Gaskets Triumph 1
KVH General Tech Figure 8s Triumph 7
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
2wrench TR6 Horny car just won't quit. On top of that, likes diesel. Go figure. Think mechanics Triumph 9
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
2billydavies TR2/3/3A question about Figure of 8 installation Triumph 9
F White smoke and I cant figure it out. Spridgets 17
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
B MGB Go figure! lucky day today! MG 3
M can not figure out search FORUM Navigation Questions 1
KVH Figure 8 Gasket Info Triumph 0
newmexTR3 How do you figure out a cam's valve clearance Triumph 2
regularman Still trying to figure this overheating thing out. Spridgets 35
Luke_Healey How do I figure out what kind of brake fluid? Spridgets 24
PATR8 Wedge TRy to figure this TR7 out Triumph 10
jdubois Ok, the Triumph guys couldn't figure this out... MG 17
regularman This here is what I figure I am going to do Spridgets 12
Rob_P Trying to figure out wgich carpet piece goes where MG 7
jaybird Figure this one out please! Disappearing gasoline MG 37
M If I could just figure a way...... Austin Healey 2
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
R TR2/3/3A Steering Box Gaskets Triumph 4
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
O MGB Gaskets and seals MG 15
J TR2/3/3A Gaskets Triumph 9
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
JimLaney New to engine building - gaskets Spridgets 2
KVH TR4/4A Rubber Door Gaskets Triumph 8
Bob_Spidell Gaskets and clearances Austin Healey 5
D TR2/3/3A GAskets and spacers/shims Triumph 5
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
B Gaskets for Trunk Lid Hinges Austin Healey 9
B TR2/3/3A Guage bezel gaskets Triumph 13
Rob Glasgow Carb Banjo Gaskets Austin Healey 8
Jeepster BJ8 exhaust down pipe gaskets Austin Healey 6
tinman58 TR5/TR250 Extra gaskets Triumph 3
Lutz Kramer Carburetor gaskets Austin Healey 8
S TR4/4A Can Anyone identify these gaskets? Triumph 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
