Figure 8 gaskets, I recently received a copper figure 8 gasket in my set and that got me thinking about what would be best. At first I was going to use a steel one with a couple of coats of silver paint on it and put it in dry. Now I am thinking perhaps the copper gasket is the way to go because of the softness. In the day, when I would have an engine rebuilt at shop they would charge a hundred dollars a hole and put the gasket in dry with a couple of bolts holding down the sleeves and I never had any problems, but the last motor I did had a non-compression water leak, and I am not sure where. On that motor, I used a metal gasket with non-hardening permatex. Anyways looking for thoughts on figure 8 gaskets
