Once again, I need your help. I discovered an issue with the electrical system this spring when waking my 80B up from its winter nap. I finally have been able to put the time in to try and fix it, but haven't had much success. The issue is the loss of wipers, turn signals, gas gauge, tach, and temp gauge. Everything I've read has pointed me to the fusebox and the 3rd fuse. I've cleaned up the fusebox and changed out the fuses, but nothing. When I switched the brown wire from the 4th fuse to the 3rd just to see, all electrics worked (but remained on regardless of the ignition (key) position.) I think I traced the white-brown wire from the 3rd fuse to the starter relay (?). I disconnected the wires and cleaned up the connections. Upon starting, gauges worked, but when I turned on the turn signal tach/gauges stopped working again. Disconnecting/reconnecting white brown from starter relay(?) got them back only to be lost again. What's next??? Anyone out there have this issue before, or have an idea I can try? Thanks! Gary
