electrical issue!!! who's surprised?
jmayzer
Member
i'm running out of ideas for my 65 midget.
the car is having a problem keeping a charge. i had my generator professionally rebuilt, a new fuse box, a new battery, and a new voltage regulator, all within less than a year. regardless of all these steps being taken, i still have to jump the car every time i want to start it, the headlights are not at full brightness and the horn does not work properly unless i'm giving the car gas. i started it up last night and after it was running for a good 10 minutes or so, i tested the battery with a voltmeter and i got a solid 12.2-12.5 volts. however, even if i drive the car around for a solid 20-30 minutes, as soon as i shut it off, it's dead and won't start back up even 10 seconds later.
......help:blue:
14dna
This sounds to me as if the system is not grounding properly. Check voltage from the positive post to the engine and see what voltage you get. Also, check how for the battery voltage drops when the starter is engaged. let us know what the results are. Dave
dklawson
You mentioned that the voltage regulator is new. Did you clean the contacts inside the regulator before placing it in service? They typically ship with a protective coating on the contacts which prevents them from corrosion when in storage. The coating also prevents the regulator from working properly if it is not removed.
59diamond
I would check the voltage regulator. Even though they say they are preset that isn't always the case. I had a problem with a battery going dead and we kept replacing the generator. Finally a young kid who worked part time for the mechanic I was using at the time said maybe it is the voltage regular and the mechanic said "no it is preset". Well the kid checked the voltage regular and it was set wrong and he reset it and WALA no more problems. This was after trying three or four different generators. You should have seen the look on the mechanic's face.
jmayzer
jmayzer
Member
good news gents! apparently my old voltage regulator totally discharged my battery, so when i plugged my new one in, the battery was still giving me trouble. i charged up the battery for a solid 24 hours and now she fires right up. this is all a learning process, right?
at idle, my voltmeter is reading a about a 12.38-12.41 - sound about right? my headlights still are only at their full brightness when i idle higher though.....
cheers,
jake
dklawson
Readings close to 12.5V only indicate a fully charged battery and don't say anything about whether or not the control box is working. You will have a better idea what's going on if you drive around with a voltmeter connected to the car and observe the system voltage when the engine is turning at least 2000 RPM. For charging you want a 1V to 1.5V increase in the at-rest battery voltage (i.e. At 2000 RPM you want to see a system voltage of perhaps 13.5V to 14V).
EDIT: I forgot to mention that with the freshly charged battery the engine will be able to start quite a few times and run for many miles. Don't let that lull you into a sense of security. Measure the charging system voltage at 2000 RPM and confirm the system is charging so you don't get stranded somewhere by a discharged battery.
SaxMan
Sounds like things are coming along well, Jake. You'll have to bring your beast down here one day. We've got some great back roads around here.
SD Bugeye
Is there a ground strap from engine to body? Check that it is contacting well and no paint at the bond.
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
N Electrical issue. FORUM Navigation Questions 2
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
Gordon_Dedrick TR2/3/3A 59 TR3A Intermittant electrical issue, Triumph 5
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
K Need some help, electrical issue Austin Healey 45
6 Electrical System Issue- Thougths Please Spridgets 6
B Stumped on Electrical Issue Restoration & Tools 6
BillyB62 TR2/3/3A TR3 Electrical issue - anything obvious? Triumph 11
R Electrical issue MG 14
bugedd Electrical Issue Spridgets 5
bugedd Electrical issue, with dancing fuel gauge! Spridgets 11
prb51 TR2/3/3A TR3 Electrical issue flasher unit Triumph 3
B TR6 Need guidance on TR6 electrical issue Triumph 7
Lin Electrical Issue - Need help Austin Healey 8
G Electrical Issue MG 4
RSMTR8 Wedge TR8 Electrical Issue Triumph 14
CARSINC Sprite Electrical System Information Spridgets 2
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
