TR6 Easier starting and clunking noises
pdplot
Started 'er up for the first time in 15 days today. Took 15 seconds till she fired. Drove downtown, stopping off for a fillup at 3.25/gallon of 93 octane and discovered the cause of at least one of the clunking noises - the trunk lid. I had taped some weatherstripping around the opening but it had deteriorated and the lid was jumping up and down when I hit bumps. Before investing and more $ for weatherstripping, is there a better way to stop the lid from rattling?
P
pdplot
The rubber seal is all there. Still it rattles, living up to its British heritage, especially with the top up. "If its not rattling, its not running." Time for more weatherstripping I guess. Its back to the hardware store in the morning. I don't know if there's any adjustment.
HerronScott
Did you mean $2.25/gallon of premium? Regular (87) is $1.99/gallon and premium (93) is $2.39/gallon for most places around here.
Scott
trrdster2000
Pdplot, Have you adjusted the latch to max down or up in your case. Be very careful you don't go too far, as it will be hard to turn loose. If you can't get it to go far enough, get a tap and die set and thread it a little further. It's the top part on the boot that has the adjustment, you will have to take the two bolts out to unlock the stud.
Good luck.
Wayne
P
pdplot
I have a tap and die set - seldom used these days. I'll try to tighten the latch a bit but I've got to be careful not to make it too tight so it won't unlatch. I hate when that happens.
Scot1966
Scott
Scott, CT has the most outrageous gas tax in the nation. Gas prices are usually in the top 3 in the states. Seems like Hawaii and California are the only ones that are higher. Last night I was out with the family and noticed premium is $3.19, and regular is $2.59. ( I am in central CT. Stamford seems to always be a little higher. )
Scot
poolboy
Are you familiar with those felt pads that you can put on the bottom of the legs of a chair. They have an adhesive side and come in various shapes and thicknesses.
I put 1 inch round ones, about 1/2 inch thick, in the 2 rear most corners of the opening.
The lid rests on those pads, thereby the considerable weight of the lid does not fully compress the boot seal.
HerronScott
Scot,
Ouch, so not only higher on the low end but a higher premium differential for premium (.60 versus .40 here).
And to stay on topic, glad the car is starting easier and hope the suggestions solve your rattle. :smile:
Scott
P
pdplot
Trunk rattle gone. I just added another layer of weatherstrip on top of the original layer on the outer edge of the trunk lid. I tried adjusting the latch - but a caveat - you should unscrew it from the lid before lengthening the catch or you run the risk of having the inner nut fall into the trunk lid, never to be seen again but a potential source of an annoying rattle. Now to find the other clunk that only happens when I hit a bump - so I don't think it's a loose diff mount. I don't get the clunk when I back out of the garage or go forward thereafter.
titanic
A clunk when hitting a bump would make a loose shock absorber the prime suspect. I think I used a jam nut to insure that they stay tight.
Berry
P
pdplot
They look tight but I'll check them again. We just r & r'd the left tube shock when we installed Goodpart spacers to level the rear of the car.
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
S Easier way to rotate the pully? Austin Healey 17
drooartz It's easier... Spridgets 0
B Fitting cam beargins just got easier! MG 9
Brosky TR6 TR6 Gauge Restoration may become easier Triumph 25
Aldwyn Spitfire Easier to Work On: TR6 or Spit? Triumph 51
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
