E Type V12 PCV & Smog systems
Pinter
I'm looking to removed parts, if not all of the PCV & smog system from my V12. Many parts are old, cracked & probibly not working correctly. I am not concerned w/ emissions control. I just wish to "clean up" the engine bay, and remove some things that aren't "needed" to run. Has anyone done so?
Pinter
Deleted member 8987
Re: E Type V12 PCV & Smog systems
Lots a luck. Remove the Positive Crankcase Ventilation and you'd better have a good plan for venting twelve piston's worth of crankcase backpressure.....then, there's the fuel system.....where the system is designed for the specific vacuum leak of the PCV.....
Get a BIG drip pan for your garage floor.
EVERY bit you remove, including nuts, bolts, clamps, hoses....save.
P
Pinter
I don't plan to completly remove the pcv system, maybe mod it to vent atmosphere threw a small K&N filter. I'm just looking to do away with the piping connected to it that runs to each carb, then down to the evap tank(or whatever that tank is). I will then run a new solo vac line down to the trans, as I know the current line for it runs off the above mentioned tank.
I'm really just hoping to get a better understanding for the systems and how they work. Then I'll be able to make an educated decision on what gets removed, replaced or modded. I just know theres alot of piping installed on the US spec cars, all in the name of emissions control.
-Pinter
Bruce Bowker
Pinter - welcome to the forum. I am from Hunterdon but live elsewhere now. I keep my cars there though and have a 1972 V 12 E Type. Ran poorly until I had a lot of the vacuum hosing etc replaced. I don't think I would remove anything but would try to replace with new as time and funds allow. These cars are worth quite bit if unmolested.
Do you have any local garages doing any work for you?
Bruce
P
Pinter
Bruce, Thanks for the welcome. I am takin great care in removing parts, and have them tags & stored in my basement. I am working w/ a 71' w/ 28K orig miles.Family was orig owners. That being said, I understand the unmolested factor and am not removing anything that cannot be refitted or replaced. I have driven the car for a year w/ things the way they are,(car sat for 25+ years until april of 2010) and really don't have many issues. Just seems like when one arises, it's from the above mentioned systems.
As of now, I'm putting in all the wrench time on the car. Don't know my way around jags(hense the questions), but know my way around cars, I'm a tech for one of the dealers in flemington (german car brand).
-Pinter
Bruce Bowker
Pinter - best of luck and hope to see you and your car sometime.
Bruce
P
Pinter
Bruce, Do you make it back around to Hunterdon County often? Seems like you have a nice collection of wheels.
-Pinter
Bruce Bowker
I visit family for 3 weeks in June and usually a week or so end of October. I would like to be there more but can't get away that often. I try to catch as many car shows as weekends allow.
P
Pinter
Bruce Bowker said:
...have a 1972 V 12 E Type. Ran poorly until I had a lot of the vacuum hosing etc replaced.
I have replaced the PCV bung, screen & rubber cap, kept the attachment to all 4 carbs, but removed & capped the link pipe that runs to the "evap" canister, then onto the gas tank( I'm sure this line had cracks & leaks). The gulp valve was removed, but pipes left in placed, I capped the system off right under the throttle pedistal. I removed the belt, but left the air pump installed, removed the pipe that runs under the p/s manifold to feed the air injection, but left the air manifold that feeds all 12 in place. Again, just capped the 2 feeds @ the rear of the motor once the check valve was removed. I'm hoping to see a improvment in idel quality & stumble on acel, as most all the parts I had my hand on during this project were cracked, rotted, split, or soaked w/ oil. All has been removed or replaced.
Tonight I'll get a chance to start it up and take a run out for some ice cream.
-Pinter
B Looking for a Jaguar E-Type S3 V12 - LHD A/C unit Jaguar 0
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
Tullamore V12 E-Type Valve Covers Jaguar 10
Tullamore Custom V12 E-Type Project Jaguar 1
Tullamore Zapped V12 E-type Jaguar 9
Rick60 E-Type Series 3 V12 distributor Jaguar 5
Rick O. V12 E-Type; Should I? Jaguar 6
J V12 Door on 68 E-Type OTS Jaguar 7
T extra cooling for e-type v12 carbs ... Jaguar 1
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
