E-Type brake caliper rebuild question
billca
I'm rebuilding the brakes on a '67 E-Type and have a question. I have removed the front piston/cylinder assembly from the caliper body and used air pressure to push the pistons out of the cylinders. Unfortunately, the pistons will only come out just barely far enough for the rubber seals to be exposed and air pressure to be lost in the cylinder. I cannot remove the piston from the cylinder by pulling it by hand. It acts as if the self-adjusting mechanism is perhaps stuck just when the piston is about to come out all the way out.
Does anyone have a suggestion for completing the piston removal?
Another clue is that the pistons were not retracting and there was excessive brake drag. That's why I'm rebuilding the calipers.
Bill C.
B
billca
Larry,
Thanks for the advice. I'll keep plugging away on getting the pistons out of the cylinders.
When you say 'don't split the casing,' are you talking about not removing the cylinder/piston assembly from the caliper? (I've already done this for the right front.) What's the consequence of taking this apart and how can I reduce the potential problems?
Bill C.
Larry Kronemeyer
Some of the older calipers came apart to help in cleaning, they were a bear to reseal with all the o-rings. Piston assemblies as you have you'll do fine, they are just hard at times do to the build up of dirt and dust and hardened seals. Using brake fluid as a lube helps control the swelling of the old seal.
Larry
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
K Is there more than one type of 16P brake caliper? Triumph 14
G E-Type rear brake caliper access Jaguar 2
6 E-Type brake light pressure switch location Jaguar 5
PC X-type shooting brake Spotted 0
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
Simmo Series 3 E Type Brake Bleeding Jaguar 2
S E-Type Foot Brake Light Switch Installation Jaguar 3
jjbunn Type 16P brake calipers - replacements? Triumph 13
B Info needed: E-Type power brake tool J 31 Jaguar 0
B Tips on rebuilding E-Type power brake master/slave Jaguar 4
B E-Type brake pipe fittings? Jaguar 5
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
