DUAL WEBER 45 MCHH TRIUMPH CONVERSION KIT
  • Thread starter Deleted member 8064
  • Start date
Deleted member 8064
Any try these new carbs kit on a TR6 yet? They seem at a good price compared to rebuild old strombergs.
Any comments?
Thanks,
Vic
Guayama
Puerto Rico
73 tr6
kodanja
Re: DUAL WEBER 45 MCHH TRIUMPH CONVERSION KIT
https://www.racetep.com/wk165mchhkits.html
martx-5
Even cheaper here... That's quite a deal. :smile:
Wouldn't these fit on the TRactor engine??
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
KVH Dual Weber Carbs Triumph 4
jaybird Weber or dual SUs? MG 25
R Bugeye dual horns Spridgets 16
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
M Mallory Dual point distributor Austin Healey 0
aero3113 100-4 dual gauge Austin Healey 16
B Dual Circuit Brakes Austin Healey 3
B MGB New Dual SU's and Run-On MG 3
B Mallory Dual Point gap Austin Healey 4
apbos Interesting dual cylinder Bugeye setup Spridgets 6
F General MG Help needed with su dual carburetor identification MG 4
A TR4/4A TR4A dual exhaust specs Triumph 3
T TR2/3/3A Dual circuit brakes Triumph 2
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
andrea Dual Beam LED Head Light Cree Austin Healey 4
steveg Fiat Dual Master Cylinder Austin Healey 7
maxwedge5281 dual circuit braking system Austin Healey 29
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
C Mallory dual point recurve help needed Austin Healey 6
HealeyRick Dual Control Healey Austin Healey 2
richie TR4/4A Dual circuit brakes in TR4 Triumph 16
M Oil Feed Pipe to Dual Gauge Spridgets 9
D Dual Circuit Brake Bleeding Triumph 7
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
CinneaghTR TR4/4A TR4A Dual Exhaust Question Triumph 4
G 1500 dual SU/ DCOE throttle cable question Spridgets 5
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
W Dual Guage restoration Spridgets 10
E BE Dual Brake Line Switch Assembly Spridgets 0
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
B Dual exhaust for 100-4 Austin Healey 0
hymodyne TR6 TR6 dual chain sprockets Triumph 3
K dual master cylinder Spridgets 3
E BE w/dual line brake master....90 degree fitting? Spridgets 12
M Rebuilding Dual M/C Spridgets 1
letemglow Brake line layout with dual master cylinder MG 6
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
D pertronix for mallory dual point Triumph 5
A Dual SU carbs pacesetter exhaust MG 0
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
E Dual Brake Line Fitting Spridgets 4
