1500 Dual Carbs in, rims lost in space...
G
Well, my euro Midget 1500 dual carbs came in today, but my rims are MIA. No one knows where they are. Came through DHL, which now finalizes shipment through the post office. Yes, you heard me correctly, DHL sends the mail man to make delieveries for them. My rims got sent back due to "improper address", but the carbs had the same address. P.O didn't scan the carbs and show to still be waiting for them from DHL. Good thing they didn't get scanned by the P.O, or I never would have gotten them.
Carbs came with new gaskets, new heat shield, new throttle cable and complete air cleaner assembly. I have to admit, I'm happy with them, however; I don't think I'll use them. I didn't know you still had to notch the brace for them to clear. I thought that was only with Spit carbs. Like I said before, I'm not cutting my car. I'll probably put them on ebay after cleaning and go to Mega Squirt eventually.
I know the notch isn't big, I just can't bring myself to cut this thing. Oh well, at least I got to fondle them for a while. (I like rare stuff.)
Rims should be here in a month or so...if they find them...
(And yes, I typo'd carbs again and spelled crabs, but I fixed it this time.)
G
mightymidget said:
If you can cut your baby let some one eles do it,
ESPECIALLY if somoene else did it...
I have the skill set needed, just not the desire.
I have a very straight, clean car and wish to keep it that way. "One day" it might be worth more uncut. I believe that the should parts fit the car, not the car fit the parts.
Is there room to shift the float bowl? I'm wondering if a custom adapter could be made that would allow you to retain the proper bowl height but offset.
RickB
If done right the notch should be reversible.
The benefits of running a well sorted pair of SU's are (I am sure) obvious to you, otherwise you wouldn't have bought them.
Morris
I am with Trevor. It should not be too difficult to fab an offset that moves the float bowl forward the inch needed to clear the brace. Send them to me. I will design one for ya' then sell it to other guys in the same predicament.
JPSmit
Or better yet, sell them to me (or swap me my newly rebuilt HS4) and I'll send it to Morris
racingenglishcars
Factory clearance.
G
YIKES !!! Maggie is shivering under her cover right now. I'll move the bowls, but I'm not gonna do factory clearance. Thanks for the pic. I was wondering how they were supposed to be set up. Looks like my euro air cleaner won't fit even if I move the bowls. I don't like it that much anyway.
hpmowog
Member
Billy,
My understanding is that HIF38's will fit without having to notch the bodywork. Look for a set from an early '70's MGB. They have the same mounting flange and bolt pattern as the HS4's, but don't have the side-mounted float bowls that interfere with the bodywork.
K Midget 1500 Dual SU Carbs Spridgets 4
G 1500 dual SU/ DCOE throttle cable question Spridgets 5
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
C Spitfire Dual Carb Spitfire 1500 Triumph 10
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
