Will some walk me through the wiring of a delco alt into a system that previously had a generator. The new Alt is the typical GM 1 bolt with the 2 wire plug. I got all the mounting done but the wiring is confusing me. I have a thick brown w/ yellow stripe wire, thinner brown w/ green stripe wire, and cream w/ brown stripe wire. It's a 67 Sprite with the 1275cc. I've seen tons of different sites about how to do it and none of them are the same. Would it be better to use new wires or just splice into the existing ones?
Thanks,
Josh
Thanks,
Josh
