TR2/3/3A Crankshaft thrust washers.
John_Progess
During my engine rebuild I had a crankshaft end float of .010" so I ordered +.005" thrust washers. I thought the new set of thrust washers would be a total of +.005" but each thrust washer is .005" thicker so now using the new set of thrust washers I have .000" end float. I installed an old set on one side of the center main and a new set on the other side of the center main and now my end float is about .004" which is what I want. Is it permissible to mix these thrust washers or do I have to try to shave .0025" off the new thrust washers? I realize that the crankshaft will be off center by .0025" and is this a problem? Thanks and have a good day!
John
TR3driver
Great Pumpkin - R.I.P
Nope, mix-n-match is exactly how you do it. Off center by .0025 won't make any difference at all, tho it wouldn't hurt to check the timing chain sprocket alignment.
titanic
I would make sure to install the new thrust washers on the side that receives the thrust when the clutch is operated (rear side of main bearing cap).
Too bad Triumph didn't use 360 deg. thrust washers on the TR6&Spitfire, like was fitted on the TR2-4A.
The cost would have been minimal compared to fixing the damage that was caused by the half circle TWs wearing and falling out.
Berry
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
H Crankshaft Thrust Washers Austin Healey 2
Tinkerman TR2/3/3A Crankshaft thrust washers, 60 TR3 Triumph 6
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
mctriumph TR4/4A Busted crankshaft Triumph 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
Gerard 1098 10CC crankshaft Spridgets 14
