Crankshaft Oil Conversion Kit
mxp01
Gentlemen:
In the Fall edition of Moss' British Motoring they mention a "must do" upgrade of a crankshaft oil conversion kit. Since I am going to put a 1275 in my BE, is this something that you would recommend? Has anyone tried it? Do you know the Moss part number?
Let me know,
Mike Pennell
Tim Hollister
mxp01 said:
Gentlemen:
Let me know,
Mike Pennell
Mike,
It appears Mr Dodd (in the fall edition you mention) is referring to Moss' rear crankshaft oil seal conversion kit. The one for the 1275 is part number 297-655. And it lists for $299.95.
Try this link and it should take right to it.
Moss Rear Oil Seal Conversion Kit
With all that said, I've no personal experience with these kits or others of the same purported function. The general feeling amongst many enthusiasts is they leak, and tend to mask the reason for the leak, e.g, high crankcase pressures caused by things like blow-by past worn rings. Many folks have recommended spending the time and money to correct the real problem and when that is done, the factory oil scroll is perfectly satisfactory.
I'm sure you'll get several other responses. Wait til Hap gets on here. He ought to give you an earful! Your turn Hap! :hammer:
Tim
Does this car have a 5-speed?
I personally do not like how the rear crankshaft seal is designed. Some people claim that it works great, but I'd be willing to bet that there are nearly as many people that say it was a waste of time.
Gray_Cat
Trevor:
Do you have to use the rear seal provided with the Rivergate kit? Or, can you still use the original scroll? I had the main bearing seats/caps line bored with the scroll so I want to use that and not the Rivergate seal.
Thanks!
Roy
My original scroll seal is in place, and the rivergate oil seal is fitted in a plate that sets into the alloy backplate. (If I remember correctly).
W Crankshaft Oil Seal Austin Healey 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
J How bad do Spridgets leak oil from the crankshaft? Spridgets 18
vette Crankshaft Rear Oil Seal Austin Healey 11
R6MGS T-Series MGTC Front Crankshaft Oil Seal MG 5
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
