GT6 correct finish
lafong
new to the hobby-1969 gt6- what is the correct factory finish on the framerails,undercarriage(black undercoating?) Would changing the factory color effect value thanks
Mickey Richaud
Not sure of the answer to your questions, but assume black was standard issue.
However, I have to comment on your forum handle - lafong - as in Carl LaFong? "Capital L, small a, capital F, small o, small n, small g!" Classic comedy moment!
:lol:
dklawson
I cannot answer for a '69. However, on our '67 the frame is body colored. While the car has had some resprays over the years, the tub has never been off the frame and every bit of the frame I have seen was "white" just like the body.
Andrew Mace
This was true of all the "small chassis" Triumphs: the Herald/Vitesse range and the Spitfire/GT6 range. Chassis were supplied TO Triumph in more or less a "chassis black" finish. Body -- including doors, bonnet, etc., -- was fitted to the chassis, after which the entire assembly went through the color paint process top to bottom, inside and out. On an original, untouched car, you'll find little or no color only in the "deepest depths" of the interior. On the chassis, you'd likely see some of the original black only on the top of the chassis wherever the body fits rather snugly over it, such as most of the run of the floor pan, etc. Under the bonnet, you should see nothing but body color everywhere, as that area was much more exposed and accessible.
S BJ8 Air Cleaners - correct finish? Austin Healey 21
B TR6 Correct finish for door striker plate Triumph 2
HealeyDave 100 Grill - Correct Finish? Austin Healey 3
angelfj1 Lucas DR2 Wiper Motor - Correct Finish Triumph 14
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
