converting a BN 1 100-4 ´55 from LHD to RHD
stevebn2bj7
I have not done that job but it seems relatively straignt forward. All the mounts are there already. You will need a steering column, dashboard, pedals. May need idler and master cylinder as those will change sides as well. Assuming you are doing a restoration and will be replacing the wiring harness and brake pipes anyway.
nevets interesting article about converting classic cars to electric power Austin Healey 7
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
K TR2/3/3A Converting to Negative Ground....... Triumph 12
K TR2/3/3A Converting to Positive Ground....... Triumph 1
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
drooartz MGB-GT Decided - converting to bolt-on wheels MG 3
T Converting a BJ8 into a racer Austin Healey 8
drambuie Converting a smiths clock to positive ground Austin Healey 12
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
T converting disc wheel BN4 to disc brakes Austin Healey 12
T Stag Converting a Stag from auto to a 5 speed Triumph 3
B Converting to Neg ground Spridgets 5
AH67 Converting wheels on a 62 BT7 Austin Healey 3
C Converting to DOT 5 Triumph 6
T TR2/3/3A Converting TR3A to Wire Wheels - Torque Specs? Triumph 3
middie Converting from US to UK radiator in a late 1500 Spridgets 10
L Converting a Midget MG 8
MadRiver Converting to a Surrey Top Triumph 5
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
Z Converting Power/Torque to Metric Units Austin Healey 1
Newkie Converting Positive ground to Negative ground MG 4
QuickSilver Converting Rubber To Chrome MG 1
M Converting to RHD Austin Healey 8
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
T converting rear reflector to brake light Austin Healey 16
spit71 Spitfire Converting track width on MKIV Spit? Triumph 5
S Converting to Negative Earth Spridgets 15
Camshaft Converting BACK to lever shocks MG 5
pan Rear axle- Converting to wire wheels Austin Healey 6
drooartz Feeling stupid -- converting tachs Spridgets 11
drooartz Converting to RHD Spridgets 10
kyreb1862 Converting to SU's MG 9
T Converting a 3000 back from a V8 conversion Austin Healey 7
R Converting Rear Reflector to working lamp Austin Healey 77
S converting from wire wheels to studs Spridgets 4
A TR4/4A Converting TR4 gear box to O/D Triumph 4
N MGB-GT Converting A 77 B GT from RHD to LHD MG 7
A Converting a non-o.d. tranny to a J-type Triumph 12
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
W Converting to wire wheels MG 1
L Rust Inhibiting or Converting Paints Austin Healey 1
W Converting from American to British Bumpers? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
