clutch adjustment on 79 midget?
pethia
Member
Anyone know if you can adjust the clutch on a 79 midget with a 1500 engine? I read Haynes manual and it did not mention this.
Thanks!
jcatnite
There isn't any adjustment. It is a hydraulic clutch. Things to check for are: missing clutch fork pivot pin, air in the clutch line, backed out slave (very unlikely unless locating bolt is missing), and weak master. Beyond that, you have to go inside to troubleshoot more.
JC
P
pethia
Member
Clutch seems to be grabbing a bit close to the floor. The master clutch cylinder looks like it was replaced by PO. I was experiencing difficulty getting the shift into first and second after sitting in a lot of city traffic on a fairly hot day. Someone suggested replacing the hydraulic clutch fluid line from MC to C slave. I did this and bled out the fluid with through the slave cylinder. I have not had a problem yet, but haven't been in traffic either. I drained out all of the old fluid..it was very dirty. The new line looks to be not rubber, but a much stronger material.
BobS76
It sounds like I have been having a similar problem. All gears grind a bit when shifting up or down. A slow up-shift and a double clutched down-shift help. Clutch has to be pressed all the way to the floor.
I would think that this is more likely due to the MC or SC - does'nt a worn clutch assy have the opposite effect - acting like the clutch is depressed even when all the way up?
Bob
aeronca65t
Try this (but make sure the clutch fluid is full first):
Pump the clutch up and down fairly quickly about 5 or 6 times and then hold it down and try putting it in gear.
If it goes into gear easier, chances are, it's not fully bled.
These can be a bit tricky to bleed. Sometimes on mine, I loosen the coupling where the hose going into the clutch master cylinder (while someone holds down the clutch pedal) to get any air out of the upper part of the hose. Seems to help.
If you're sure it's fully bled, look at the clevis pin on the clutch pedal. It should fit into the hole in the clutch pedal fairly tightly.
Be sure the pin is not worn or the hole in the clutch pedal isn't elogated. Even a little slop here can translate into a lot of "lost motion".
jlaird
I have a different prob but all the above guidance is good.
I think I may have a bent fork. Think I will try to find another or at least have someone outline one on a peice of paper and send it to me so I can check mine when it is next out.
Only thing I can think of at this time is a bent fork or the thiner throwout bearing I have or both. Oh well, the next engine pull when the weather cools off will tell the tail.
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
R TR2/3/3A Clutch Petal Adjustment Triumph 2
M TR6 clutch adjustment Triumph 4
R TR2/3/3A Clutch Adjustment Triumph 18
6 Clutch Adjustment Spridgets 2
Jim_Gruber BE Clutch Adjustment Bugsy IV Spridgets 7
K TR2/3/3A Clutch adjustment with mixed TR parts? Triumph 10
RedTR3 TR2/3/3A Clutch Slave Adjustment Triumph 5
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
Zimmycobra TR4/4A TR4A Clutch adjustment question Triumph 2
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
jhorton3 Rivergate Clutch Adjustment Spridgets 6
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
CJD Brake/Clutch pedal adjustment Triumph 29
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
Nelson Clutch slave adjustment Spridgets 6
J Clutch Adjustment? Spridgets 13
M T-Series Clutch Adjustment MG 5
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
B TR6 Clutch Adjustment / TR6 Triumph 5
AUSMHLY Clutch pedal adjustment Austin Healey 6
Hegg Elan +2 - Engine Mounts and Clutch Adjustment Lotus 6
Darwin Clutch Pedal adjustment. Triumph 4
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
