Choke sticking
steveg
Bob - the cable wires are stock* solid wires.
I went to a bike shop that sells the teflon-lined housing by the foot. It's 5mm OD - it works great but is a little skinny for a BJ8 stock look.
IIRC a couple of years ago we had a thread discussing this and there is teflon-lined housing out there with an OD closer to that of the BJ8.
Re Lin: 82* C = 180* F
Addendum: * I assumed my choke solid wire was stock. I cannibalized it from my original HD6 setup. I must have bought another from the auto parts store to cannibalize for the dual HD8 setup.
OK--I'm confused (hush). I haven't looked in a while, but IIRC my choke cables, which are OEM AFAIK, are stranded. The fact yours are solid is evidently the solution.
Patrick67BJ8
Bob - the cable wires are stock solid wires.
I got mine from BCS and to make them look good and thicker for the cable holders I used a electrical plastic sleeve material I got from British Wiring. I also used some black heatshrink to better secure the ends to the cable inserts.
mountainman SU Choke sticking! Help Triumph 6
Steve P. 1500 Midget; sticking choke Spridgets 6
George Zeck Choke is sticking ??? Spridgets 11
B Sticking throttle and choke knob question Spridgets 9
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
