Castrol DOT 4 vs Other Brands
AUSMHLY
1964 BJ8. I've always used Castrol LMA Dot 4 brake fluid. It's time to flush the system. Believe it should be changed every couple of years. Currently Castrol isn't in stock locally or online from places I used to buy it from. When I do find it, it's selling for much more then it used to. Some are twice the price. Supply and demand?
Why is Castrol recommended for the Healey?
Thoughts on Prestone, Valvoline, Lucas Dot 4.
kozelding
IMHO, DOT 4 brake fluid is DOT 4 brake fluid — I've used Valvoline (which my local auto parts store stocks in large bottles) for years without issue.
(I've also duly used Castrol LMA when available, which might get dark slightly faster than the Valvoline stuff, but otherwise seems no different performance-wise or parts degradation-wise. I also dutifully change my brake fluid every handful of years.)
bdcvg
Originally Castrol was needed because other brake fluid would eat the rubber seals on the wheel cylinders. I believe the seals are a different compound now and it's not an issue.
Platinum
Castrol has been hard to find here as well, but as others say, DOT 4 is a standard and all DOT 4 should be the same. Early recommendations were as bdcvg says, the seals were deteriorated with other fluids. Time marches on, better hydraulic seal compounds and ethanol resistant fuel lines are good examples.
I found Castrol LMA available through a local Harley-Davidson (of all places!) shop but had to "special order" it. A case of pint bottles at a time. Figured that was not a bad thing, in that using small bottles with not much remaining in each was better than an opened quart, half-full and sitting on the shelf for some extended time.
LarryK
Available online at Roverparts.com and MiniMania, miniparts, etc. Have at my local Advance auto parts store. Amazon too.
prb51
I had a leak in the master on my TR3 that dripped down the fire wall and into the cockpit....really screwing up nice paint. I bought a gallon of milspec military DOT 5 silicone and purged the system and changed out. No hydroscopic, high temp levels better than Dot 4 and if it ever leaked no issues.
I did not note a soft pedal it felt exactly the same as the Dot 4.
I will do the same to the 100-6 in short order.
Jim_Gruber Brake Fluid - Castrol LMA Dot 3 or Dot 4? Spridgets 2
AUSMHLY Castrol GTX Classic vs Valvoline VR1 Austin Healey 6
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
tahoe healey Castrol oil again Austin Healey 37
tahoe healey What's with Castrol Oil? Austin Healey 9
Morris Well shoot! Castrol Edge 20w-50 discontinued. Spridgets 13
RAC68 Motorcycle Oil Castrol 4T 20W50 Any Information Austin Healey 15
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
Jim_Gruber Castrol GTLMA - Full Synthetic Spridgets 4
bthompson Castrol LMA going away? Spridgets 5
tahoe healey castrol brake fluid Austin Healey 10
Ed_K Castrol Syntec 20w-50 no longer available ? Austin Healey 21
bighealeysource switching out brake fluid from silicone to Castrol Austin Healey 4
PeterK Castrol Edge full synthetic Triumph 2
Bruce_B Castrol Oil for Classic Cars 20W 50W Spridgets 2
M Castrol for "CLASSIC CARS" 20W50W Triumph 22
C Castrol on sale at NAPA Austin Healey 2
B Castrol Oil Recomendations for Classic Cars Triumph 3
tahoe healey Castrol oils Austin Healey 1
PAUL161 Castrol Buyout ? or Rumor ? MG 2
C Castrol LMA Lo Moisture Absorbsion and Natural Triumph 43
SCguy Engine Oil, Castrol 20/50 Triumph 17
coldplugs Castrol R racing oil Restoration & Tools 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
R TR2/3/3A Dot 5 Triumph 8
KVH General TR Dot 4 Brake Fluid Triumph 7
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
Rhodyspit75 DOT 5 and DOT 5.1 Spridgets 1
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
S TR2/3/3A Question on the lift dot fastener, Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
T TR2/3/3A Lift the Dot question Triumph 4
TulsaFred Timing Gears dot to dot Spridgets 9
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
NutmegCT brakes: DOT 3 or DOT 4? Restoration & Tools 2
C TR6 Dot 5 in a TR6 rebuild Triumph 17
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
M Tennax and Lift A Dot? Spridgets 2
M Lift-the-dot peg Triumph 3
S dot 5 brake switch Triumph 14
