camber plates and Texas Kooler
BoyRacer
Please describe what you say are "camber plates"
Keoke
Keoke
OK !!
That makes sense ,since you half to move the shock in or out to change camber.:encouragement:
John Turney
What was confusing was that they are shown as NOS camber plates. Made me think they might have been an original part.
D Adjustable camber plates Austin Healey 19
C Adjustable camber plates Austin Healey 5
T Camber Settings Austin Healey 12
B Front Wheel Camber Setting Austin Healey 8
A Setting Camber Really Off Austin Healey 13
Bob_Spidell Camber Adjustment [again] Austin Healey 24
V 89 XJ6, How to adjust front camber? Jaguar 2
AUSMHLY Wheel Tire Camber Austin Healey 57
Sopwith_Camel positive camber xj Jaguar 0
Born_Loser Spitfire Swing Spring vs Camber Compensator Triumph 10
tahoe healey Camber Austin Healey 22
bthompson Relationship of bachelor lean to front wheel camber? Spridgets 5
DanLewis Correcting positive camber in a Bugeye Spridgets 21
HJR TR2/3/3A Camber on TR3A Triumph 7
H camber adjustment eccentric bushings Austin Healey 15
R Negative Camber 78 Eclat Lotus 8
B Another Camber/Caster Problem Austin Healey 36
regularman Camber Spridgets 12
M Sudden Camber Issue Wrecking Good Tires Spridgets 7
I TR6 TR6 rear camber help Triumph 16
Trevor Jessie Positive camber Spridgets 20
Steve1970 Bumpy ride solves negative camber problem! Triumph 7
Jarhead Negative Camber MG 5
8 NEGATIVE CAMBER Triumph 1
A Rear camber findings and adjustment recomendations Triumph 4
A TR6 Goodpart camber adjusters--possible problems?[TR6] Triumph 6
jerrybny TR6 Rear Camber on a TR6 Triumph 17
Nunyas negative camber wishbones... MG 7
B Castor/Camber Corrections Austin Healey 2
Radford Setting Camber MG 6
G TR6 Homemade camber gauge for TR6..... Triumph 7
T Camber Compensator Triumph 7
Mark_Gibson TR6 TR-6 Positive Rear Wheel Camber Causes Triumph 8
Nunyas Negative Camber wishbones? MG 6
bighly Camber adjustment on Big Healey Austin Healey 16
Mark_Gibson TR6 Positive Camber Solution for TR-6 Triumph 0
J uneven camber-- causes? Triumph 9
R 10 degree camber Spridgets 3
B TR6 Negative Camber 74 TR6 Triumph 5
B TR6 negative camber - 74-tr6 Triumph 5
B Spitfire Spitfire Mk3 Rear Wheel FREE CAMBER VALUE Triumph 4
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
A Later drum backing plates - hub not clearing Spridgets 2
T TR6 bulkhead number plates Triumph 1
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
