TR6 bulkhead number plates
Trumphman
Does anyone know of a source for the bulkhead number plates. I removed several years and one move ago prior to stripping.
Now that I'm finally reassembling they're missing.
Jim_Gruber And so Bugsy II Restoration starts/Shell Number/ RS Bulkhead/Evaporust works Spridgets 1
ckeithjordan TR2/3/3A TR3 Bulkhead Carpet Triumph 9
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
TomMull TR2/3/3A Flooe panel to bulkhead joint detail Triumph 3
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
Jim_Gruber Looking for SU Fuel Pump mounted on RR Bulkhead pics Spridgets 2
M_Pied_Lourd TR2/3/3A Bulkhead Blanking Plate Changeover Triumph 10
H Rad bulkhead plates production run? Austin Healey 8
F Seal between transmission tunnel and the forward bulkhead Austin Healey 7
Jim_Gruber Bugsy II - Bulkhead Repair Questions Spridgets 12
T TR2/3/3A tr3 bulkhead holy question Triumph 13
5 BN4 rear bulkhead vinyl trim Austin Healey 10
B TR2/3/3A Where did I see the picture of the TR3 bulkhead Triumph 6
angelfj1 TR2/3/3A TR3A Bulkhead Earthing Point Triumph 8
bighealeysource Fit of extension panel to gearbox cover & bulkhead Austin Healey 6
T New bulkhead panel is in Triumph 5
H TR2/3/3A TR3A Rear Bulkhead Triumph 9
T TR2/3/3A What is a bulkhead supposed to look like on a TR3? Triumph 15
TR4nut TR2/3/3A Mystery holes etc in TR3A bulkhead Triumph 14
angelfj1 Bulkhead Sealer Plate Triumph 5
Dudly Spitfire Spitfire bulkhead Triumph 11
newmexTR3 TR2/3/3A TR3 trunk bulkhead install Triumph 7
chicken Routing of oil pressure pipe through bulkhead Austin Healey 2
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
chrisc Rear Bulkhead Panel MG 16
martx-5 TR2/3/3A TR3 Bulkhead Sealer Plates Triumph 2
C TR6 Transmission Number Meaning Triumph 5
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
T VIN Number Austin Healey 2
C Spitfire Red painted engine number Triumph 3
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
M Year and Vin number Spridgets 5
Pool Dad 1960 TR3 engine serial number Triumph 14
R Engine Number Plate Austin Healey 2
Guido36 Chassis Number Issue Austin Healey 11
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
RJS General TR Commission Number Plate Triumph 13
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
X Production year based on body number ? TVR 3
S TR6 Chasis number, engine number register Triumph 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
RickPA Mounting number plate on front bumper Austin Healey 4
V Gearbox number Austin Healey 6
D TR2/3/3A Gearbox number? Triumph 8
S TR2/3/3A Koni shocks part number? Triumph 2
