Gearbox number
vlust
Hi,
On the underside of the gearbox I noticed on two different places the same number that I do not understand. The number is "10D59" My car was built in 1959(Healey 3000 Mk.1)
Can anyone help me to explain this number?
regards,
Victor
BN6
Member
Just a wild guess, but if your car is a 1959 3000 MK1 maybe the numbers mean the following. 1=MK1, OD=Overdrive, 59=1959.
pan
G’day Victor, As a 100 owner I’m not too well versed on details of the later models but what BN6 has suggested makes sense on the face of it, except that the first 3000 model would only have become the “MkI” when the MkII was introduced. Just as the 100 only became known as 100/4 when the 100-Six came along.
Cheers,
Alwyn
healeyblue
Could be a date code. German cars have lots of parts with date codes stamped on them. 10th day of April (D) of 1959
V
vlust
Thanks for all the suggetions. The date code seems to me the most likely explanation since my car was produced in May 1959 according to the heritage certificate. So April 1959 would fitt into that explanation.
I will certainly follow up on the tip of the Teflon tape.
Jack T
The paste that's sold in tubes for natural gas fittings (PFTE, maybe?) Is gasoline and oil resistant. Easier to apply and more likely to stay in place than the tape.
D TR2/3/3A Gearbox number? Triumph 8
M TR4/4A TR4A Gearbox Number Mystery Triumph 2
I bugeye gearbox number location? Spridgets 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
