cable linkage for SUs
eejay56
I am converting a Spit to dual SUs and need to find a way to attach choke and throttle cables to the linkage. Any suggestions or pictures of how you've done it?
philman
I did it on a TR7. Would the linkage be similar?
eejay56
eejay56
Hey Phil, I saw it but I didn't look that closely at the linkage. The thing I'm having a problem with is finding something to connect the cable to the lever for both the choke and throttle. Are you going to the autocross next weekend? I'll be there Sat. I think FSP runs in the afternoon. There's one in Salem Sunday.
philman
planning on playing chess at U of O tournament saturday and autocrossing on sunday in eugene. Wife may run as a novice on sunday also. I will probably show up late saturday afternoon. I put 215/50's on my convertible and had the brake pressure valve modified.
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
T Ratco cable linkage - diagnostics Triumph 5
J Healey 3000 - throttle linkage [cable] Austin Healey 11
T Ratco carb cable linkage Triumph 21
philman Wedge TR8 Throttle Cable linkage help Triumph 3
T Ratco cable linkage review Triumph 5
T Carb Cable Linkage Triumph 22
Brosky Ratco Cable Linkage install on Tri-Carbs Triumph 16
Lin Carb Linkage and Throttle Cable Austin Healey 3
Lin throttle linkage/cable Austin Healey 3
B Replacing the Handbrake Cable Austin Healey 8
KVH General Tech Heater control valve/cable Triumph 1
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
D BT7 Air Vent Control Cable Routing Austin Healey 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
Bayless Help please installing bonnet release cable Spridgets 8
B tachometer cable has a hole in it Restoration & Tools 7
D Choke Cable Length Austin Healey 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
R Bugeye heater cable Spridgets 12
George Zeck Speedo Cable? Spridgets 3
steveg Battery Cable Specs Austin Healey 33
Walter74 Throttle Cable Conversion Austin Healey 6
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
P TR6 Jumpy Speedometer cable Triumph 4
E Oil leaking from the Tachometer cable Austin Healey 5
TomMull TR2/3/3A Which choke cable Triumph 12
P TR6 72 TR6 Speedo cable Triumph 2
S Routing of Hand Brake Cable Austin Healey 6
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
Marvin Gruber BJ7 tach cable location. Austin Healey 3
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
FlyingCat Spitfire Accelerator cable Triumph 4
B TR6 TR6 Hood Release Cable Triumph 7
sparkydave 1500 battery cable colors Spridgets 1
JFS TR2/3/3A Wiper Cable Lube Triumph 5
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
M TR4/4A Speedometer Cable Routing Triumph 7
S TR2/3/3A Routing the OD speedo cable Triumph 9
F TR2/3/3A Choke Cable Problem Triumph 29
