Bugeye Top Bow repair
BWillis
Does anyone have any experience repairing the springs in the top bow? I was very lucky to buy a very nice looking bow from Ray in TN on the floor and lots of rust comes out.
Do you think that several soakings in pb blaster would loosen it all up? It doesnt appear to come apart.
jlaird
As far as I know does not come apart. Soak it and resoak and work it, prob will be fine.
Sarastro
Mine originally was a wreck, too. I just oiled it to loosen up the spring mechanism, then painted it. No great difficulty with painting, and I'm happy with the results. If you have a lot of loose rust (I just had a small amount), you probably need to get rid of most of it or you'll have a mess in the car. My first preference would be to shake it out, but this may not be good enough, and you'll have to use some kind of remover. Then, you need to get rid of any residual rust remover (which might be acid) and any water needed to flush it.
R BUGEYE SOFT TOP FIT Spridgets 2
Keith_M bugeye top bows Spridgets 3
Rut Bugeye shifter cover [top hat] Spridgets 6
Desert Rat Bugeye soft top Spridgets 2
M Bugeye Hard Top Parts Spridgets 22
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
T Is this a Bugeye top frame? Spridgets 9
J Bugeye single piece top frame same as two-piece? Spridgets 4
J Need Bugeye top frame; Have older Sprite top frame Spridgets 21
I Bugeye top and tonneau help please Spridgets 9
I How do I store top in Bugeye? Spridgets 6
drooartz Source for Bugeye top - rear bar Spridgets 13
6 Front Steel Insert For Bugeye Top. Anyone Have One Spridgets 7
6 How to install Bugeye top? Spridgets 2
I Suggestions for new Bugeye soft top? Spridgets 3
AngliaGT Bugeye Top Bows Spridgets 1
I Source for Bugeye convertible top? Spridgets 6
M Bugeye Top Installation Spridgets 2
I bugeye convertible top frame painting Spridgets 1
I Factory Bugeye top Spridgets 25
B Bugeye Top Bows Spridgets 1
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
