Bugeye shifter cover [top hat]
Rut
Now that the Bugeye is back from the painter I’m assessing the parts I need to finish it. The car was at the body shop when we had the fire and most of the parts were with it or in the garage when it happened. Now that the car is back I’ve noticed that a few items are missing that I was unaware of. One is the ‘top hat’. I had two, one stock with insulation and painted and the other was 3/4” lower and painted...I’m guessing both went up in smoke. If anyone has an extra I could really use one!
Thanks, Rut
Rut
Rut
The painter called and he found it on the rack with some other goodies...I’m good to go!
Rut
drooartz
Woohoo! :cheers:
Rut
Rut
The painter called later and said he’s still looking and the shop ain’t that big!
Rut, disappointed in AL
twas_brillig
Jeff has his lowered fibreglas replacements available in case you're stuck. Doug
Rut
Rut
Thanks again guys! BillM had one he’s shipping along with a few other parts I need AND the painter called again to let me know he mailed mine yesterday...I’m pumped. I’ll have the original ready to install and an extra to cut down if necessary. Can’t wait to get the engine and transmission installed and the aluminum back from the polisher/anodizer. I’ve removed most of the under bonnet parts and pieces to clean off any overspray and repaint some of the black pieces and that gives me more room to color sand and polish all the paint work.
Rut
drooartz Bugeye shifter on later ribcase Spridgets 3
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
