Hello,
I need some help/thoughts in two areas. I am getting to the end of my restoration on my 60 bugeye. I need more money to finish the paint job. Does anyone know the value of a factory hard top? Where I live now does not really lend itself to a hard top anyway. It still has the original glass, and the chrome was replated a few years ago. The rubber seals could probably use replacing at some point. The hard top has no damage except for a small 3/8" hole throught the top. There is no structural damage to the sides, which seemed to be typical when I was looking for a top. Some of the gel coat appears to have flaked off on the inside.
The second piece of information I need involves restoring the top? How easy is it to remove the rear window (so that I could apply a gel coat and paint it)? What would be involved in applying a new gel coat? How do you repair the small hole? If you were to sell this hard top, would you just be more inclined to sell it as is?
Any suggestions would greatly be appreciated.
Kevin
Kevin
