BT7 3000 - Push rod problem on clutch slave cylinder
fishyboy
Hi all, this evening a friend installed a new clutch master cylinder and slave cylinder on my 1961 Austin Healey 3000 BT7. On removing the slave he noticed that a small nut had been put on to the end of the slave cylinder push rod by a previous owner (I have owned that car for 25 years so it was some time ago!).
Why we wondered?
We put on the new slave (without the nut) and bled the system. Low and behold without the nut we where unable to engage gear as there was very little movement on the clutch pedal. Realizing that the the nut had been put there for a reason we removed the push rod from the slave and replaced the nut (1/4 " in width) and hey presto we then got more movement on the pedal and could engae all the gears. the push rod appeared to be a standard size.
Does anybody know whats going on? We assume that the real problem lies inside the gear box. What would be a better solution (without going inside the box)? We guess an ajustable rod might work, but have not been able to find one from one of our usual supplies here in the UK.
Any help welcome.
Phil
Brinkerhoff
Drive it with the extension on the rod until you need a clutch ( soon). The parts are wearing thin and you are running out of leverage.
RA_Healey
To much slop due to wear has developed over the years and the nut compensates for the distance throw. As has been said, you will eventually need to pay attention to this.
Keoke
The replacement Clutch Master clynder should have had an adjustable push rod on it ??
F
fishyboy
Hi all,
Thanks for all the advice.
It sounds like the only long term solution will be found when the clutch is replaced.
I have mamanged to find a slighty longer push rod (Dennis Welsh?) which might be a better stop gap than the nut!
My new MC's did not come with adjustable push rods.
We l also noticed that neither the brake or clutch MS wheer shimmed. Does anyone think adding the shims would make much difference.
Many thanks
Phil
Keoke
I think the shims actually limit the distance the push rod moves the piston in the master cylinder.?
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
J 3000 [BT7] with 100-6 Grill Austin Healey 2
S Aluminum wing vents for BT7 3000 Austin Healey 1
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
F Carpeting Austin Healey 3000 1961 BT7 Austin Healey 10
B Oil Pressure Issue Solved 3000 BT7 Austin Healey 1
D BT7 62 3000 Trans leak Austin Healey 2
A Healey 3000 MKII BT7 restomod Build Thread Austin Healey 67
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
D Center Shift 3000, BT7, slipping Austin Healey 1
C Removing windshield from Austin Healey 3000 BT7 Austin Healey 2
tri_carb_healey drain plug bolt size 3000 bt7 Austin Healey 6
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
J 1962 3000 MKII BT7 Water pump replacement Austin Healey 3
mrdibbles Abarth Exhaust System for Austin Healey 3000 BT7 Austin Healey 11
pbraun I thought it was a 100-6, but it's a BT7 3000 Mk I Austin Healey 5
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
T BT7 Hardtop Restoration Austin Healey 6
