TR2/3/3A Broken exhaust manifold TR3b
kstanley44
Hi all,
See attached. Can an exhaust manifold with a broken flange be fixed or is it toast? So far I have not gotten the exhaust pipe off although I haven't tried heat yet.
Thanks,
Kerry 62 TR3b frame off restoration started
TR3driver
Great Pumpkin - R.I.P
Can be fixed, if you find the right welder/machinist. Lots of work, though, probably not worth the cost. I'd look around for a replacement instead.
CJD
It's toast.
Exhaust manifolds get so hot in use that the metal structure changes. The carbon turns to graphite and makes the metal hard as rock. Welding will not work.
Fortunately, TR3 manifolds are both plentiful and cheap. I think I still have the one from my donor car if you'd like me to check.
TFB
Hi all,
Thanks,
I have welded lots of cast iron,from vintage motorcycle cylinders to coal stove shaker grates,and agree with Randall, not worth the time to grind back to clean metal,build up with weld and machine hole and flange if replacement is available.
Tom
martx-5
Good excuse to install a header...:excitement:
CJD
I'm not saying it can't be welded...I'm saying the weld won't hold. Think of it this way: the manifold gets heat treated every time the engine starts. It amounts to thousands of heat treats, and eventually the grain structure reaches a point that the original grain lattice cannot be recovered with further heat treating.
I've also welded blocks, heads, crankshafts, intakes, you name it. As a young gearhead teen I could not figure out why I could never weld exhaust manifolds with any success. Weld looked beautiful...and cracked. Do it again...cracked again. Later, I studied metallurgy in school, and learned that exhaust manifolds are hardened to the point of no return! The grain structure of the weld can never be matched to the over-treated structure of the manifold, no matter how much you preheat, cool controlled, or otherwise prep the weld. It will end up brittle. A brittle weld may, possibly, last on a grate, but it will never take the load of that stud on the manifold.
Another way to put it...I could weld that for free...and I have saved many a lost part from the grave for no other reason than the challenge of trying it...but I still would not attempt Welding your manifold. It has no chance of success.
TFB
Did you ever try nirod electrodes?For example Mg industries makes a MG289 for cast iron.The trick in my opinion is grinding back to clean metal,carefull welding with proper electodes.
CJD
Good (pricey) rods. They would work well on heads and blocks. Have you tried them on an exhaust manifold? It's not the quality of the weld that is the problem...it's the hardening of the old manifold.
TFB
Luckily I sourced a supply while employed so cost wasnt a factor.Indian flathead exhaust port nipples get hotter than auto manifolds and I have successfully welded both.
Multiple passes you have to peen the bead to stress relieve.Lowest heat otherwise porosity.My guess is you would get the hang quick.
If you sent me a self addressed envelope I will put a few rods in for you to try or have on the shelf.
K
kstanley44
Thanks all for the metallurgy lesson!!! It sounds like I should be looking for a replacement manifold. John, you mentioned you may have one. Did they change any over the TR3 run? Mime has the following casting number: DA14221 and under that 304164.
Take care,
Kerry
TR3driver
Even TR4 exhaust manifolds are the same. Didn't change until the TR4A was introduced.
CJD
Take care,
Kerry
Just got back in town...I'll check and PM you...
davester Help needed...broken exhaust manifold stud MG 15
J Need some expertise, broken exhaust maniford Triumph 9
abarth69 Broken Exhaust Stud Removal Spridgets 12
guzzul Spitfire Help! Spitfire 1500 exhaust flange studs broken. Triumph 16
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
K What is this broken part in my transmission/OD? Austin Healey 6
tahoe healey Broken Spokes Austin Healey 8
H broken sway bar link - again Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
H broken sway bar link Austin Healey 13
K TR2/3/3A Crossshaft broken taper pin removal? TR3 Triumph 5
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
tahoe healey broken spoke Austin Healey 12
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
K BROKEN ROD BOLT has any body had one? Triumph 9
