TR6 Brighter instrument lights?
edkap2002
My 72 TR6 experienced a start problem which I posted a thread on and received much good advice. Upon resolving the issue, I realized that I may have cured another! Dim instrument panel illumination!
Here is the upshot of my starter problem!
Cable on starter from battery was one quarter turn loose.
I removed battery cables, cleaned terminals (which were not showing signs of corrosion).
I removed power cable from starter (filthy but not corroded), cleaned terminals, sprayed with electrical connection cleaner, reattached and tightened properly.
While I was at it, I changed out the 52 year old fuse box as I suspected that the terminals were not as conductive as they were when new.
Result, my 72 TR6 cranks right up and starts immediately.
ADDED BONUS........MY INSTRUMENT PANEL LIGHTING IS BRIGHTER THAN IT HAS EVER BEEN IN THE YEARS THAT IVE OWNED THE CAR. i CAN ACTUALLY SEE THE COLORS ON MY TACH AT NIGHT!
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
I Solution for brighter dash lights? Triumph 14
T BRIGHTER DASH BULBS.......anyone have numbers Spridgets 10
PAUL161 Brighter Lights-[Cheap] MG 1
healeyboz brighter side of things Spridgets 7
AUSMHLY How to: Brighter gauge face with LED’s. Austin Healey 78
A brighter light... Triumph 15
G Rear lights brighter than ever.... Triumph 1
Brosky Brighter dash light bulb saga continues Triumph 17
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
LAW75 Instrument Panel Lights Austin Healey 9
bighealeysource LED Instrument Lights Austin Healey 12
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
Crankshaft TR2/3/3A Instrument troubleshoot Triumph 7
steveg Improved Instrument Lighting Austin Healey 2
Crankshaft TR2/3/3A Instrument panel cleanup Triumph 4
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
Gerald_Gordon TR4/4A TR4 instrument panel Triumph 7
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
S Instrument Panel Lights Spridgets 6
R TR4/4A Question about cleaning instrument faces Triumph 8
MGTF1250Dave T-Series TF Dash Instrument Panel Studs Size MG 2
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
CJD General TR Instrument Faces Triumph 111
Jim_Gruber Instrument Bezels for BE Instruments Spridgets 4
Gerry M TR6 Instrument panel light bulbs Triumph 1
L Instrument O rings and switch plate mounting Austin Healey 4
Nelson Instrument bulb replacements Spridgets 14
T current instrument rebuilding info from Nissonger Austin Healey 3
M TR4/4A tr4a instrument knob removal? Triumph 9
T XKE Series 2 Instrument Panel Jaguar 2
M Instrument lights, etc. Triumph 8
AH100M 100/4 Instrument panel silver paint Austin Healey 5
Tinkerman TR2/3/3A TR3A Dash and Instrument Cluster Installation Triumph 11
Tinkerman Bench Testing a Wired Instrument Cluster Triumph 7
ekamm TR2/3/3A removing tr3 instrument panel Triumph 15
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
Tinkerman Instrument Cluster Assembled, YEA ! Triumph 22
Tinkerman TR2/3/3A Instrument Cluster TR 3A Triumph 14
J TR2/3/3A TR3A instrument restoration Triumph 11
Nelson New instrument lamps Spridgets 10
HerronScott TR4/4A Smith's Instrument List for TR2-4A? Triumph 1
Tinkerman TR2/3/3A Instrument Panel TR3, Question about back. Triumph 29
T MGB MGB Instrument Lighting MG 7
B instrument led lamps Austin Healey 12
prb51 TR2/3/3A TR3 instrument lights Triumph 4
J Removing Healy wood instrument panel BJ7 Austin Healey 3
