Hello,
I have a 1967 Healey 3000 MKIII BJ8....the breather tube that comes out of the valve cover and connects to the air filter of the rear SU HD8 carb....keeps dumping oil into the air filter and then into the carb.
Someone recommended that I take an empty quart of oil and attach it to the rubber hose...and let the oil drain into the empty quart.
Would anyone have any suggestions? Is it bad to have the oil in the air filter and then burn thru the carb?
Thanks!
Thanks!
