Oil Leak at Breather Tube
Earl
After 2 weeks of getting the 61 TR3 running, after a 15 year storage, we have a heavy oil leak at the breather tube. /ubbthreads/images/graemlins/cryin.gif Oil appears to be seeping out around the tube. Is it possible to remove the tube without removing the engine, how, and what should I do after I get it out?
Thanks for any advice, BTW the fuel pump is not leaking, but is also not in use as we replaced it with an electric pump.
Earl
pace
The only way I solved this problem was to install new piston sleeves and rings. It stopped it completely. Mine really started leaking after I had a valve job and I think the extra compression forced oil by the old rings.
Louie
I just did a valve job on the MGB, now I have a drip at the breather.
The breather is right above the exhaust headers. Temporarily, I attached a vinyl tube to extend the drips below the exhaust,
to stop annoying burnt oil smell.
Geo Hahn
[ QUOTE ]
[/ QUOTE ]
Sure. It is held in place by just that one oil pan bolt and a bit of friction in the block hole. The fitting is split so it shouldn't be too tight to work out, just a snug fit. Maybe a bit of Permatex Aviation form-a-gasket would help seal it?
You will probably need to remove the mechanical fuel pump if it is still in place -- might be a good time to replace it with a blanking plate if you're so inclined.
Best not to mess with the length of that tube or add a catch can... that guy is carefully designed to pull just the right bit of vacuum when underway.
Famous story about that tube involves the TR2 Jabbeke run when a junior mechanic decided (on his own initiative) to extend the tube to clear the undercar aeroshield. The result was a tube that sucked most of the oil out of the engine on Richardson's first run. The problem was corrected and fortunately the engine held together for the remainder of the high-speed runs.
I MGB Sprung an (oil) Leak! MG 2
B Oil (or Coolant) Leak Austin Healey 10
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
B Phanton Oil Leak Spridgets 12
I Bugeye oil leak help Spridgets 4
Zitch Engine Oil Leak After Long Drive Austin Healey 19
2 TR2/3/3A Oil leak in tranny Triumph 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
steveg Strange Oil Leak Austin Healey 7
TomMull TR2/3/3A Transmission oil leak Triumph 17
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
D BT7 Oil Leak at Distributor Austin Healey 5
J TR4/4A Oil leak from rear of motor. Triumph 28
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T Oil pan leak? Spridgets 7
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
C oil leak Spridgets 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR2/3/3A Locating source of oil leak Triumph 6
Jim_Stevens TR2/3/3A Trunnions oil leak Triumph 2
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
Martinld123 Problems with Oil Leak From Distributor Austin Healey 2
T TR2/3/3A coil mounting bolt oil leak Triumph 2
4tecdog BJ8 Overdrive oil leak Austin Healey 6
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
TulsaFred Front engine oil leak Spridgets 33
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
Sixpack TR6 Bad Oil Leak Triumph 24
T Gear Oil Leak Austin Healey 17
Rut Bugeye oil leak Spridgets 8
J Found an oil leak Austin Healey 7
V Problems - Oil Leak and Manifold Pressure Austin Healey 1
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
J Engine block modification for oil to water jacket leak Austin Healey 8
apbos We have Vroom, Vroom and an oil leak from the Oil Filter! Spridgets 11
Gliderman8 TR6 Oil Leak found! Now what? Triumph 26
S Rear crank seal oil leak BN2 Austin Healey 20
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
johnrip Wedge TR7 Oil Pump Leak Triumph 2
RJS Oil Leak Questions Triumph 10
dklawson Oil Leak - I Screwed Something Up. Triumph 8
Bob_Spidell Oil Leak BN2 Austin Healey 2
