Bugeye oil leak
Rut
Guys,
The welding on my Bugeye is nearly complete and I finally turned my attention to the engine and transmission. The 1275 has always been a leaker when running with some success using a variety of crankcase venting. I finally separated the engine and transmission (smooth case) and the inside of the bell housing had no oil stains! I always assumed the scroll seal was the culprit, but the leak has got to be elsewhere. I'll pull the clutch, flywheel, and rear plate and hopefully find the answer...any suggestions?
Rut
tomshobby
Hi Rut,
Mine had 2 leaks, both from fittings on the engine. The rear line to the oil cooler and the fitting for the oil pressure gauge line. Both needed to be tightened. I think it is also having some get past the rings but with only 700 miles on the engine that will probably lessen over time. For now the car is in storage until spring.
Tom
Billm
Rut
You may just have a loose oil pump that is leaking- can only tell when you pull the backing plate off to look
BillM
jlaird
As the local expert ( Niceville FL folks ) if I may have the floor. Oil leaking from the scroll seal actually does not get into the bell housing, it leaks out from between the oil pan and the rear engine plate. In any case that is my story and I am sticking to it.
Gerard
That's absolutely correct.
nomad
You can also have dried out and shrunken pan gasket's that will leak from the same area. At least that was my experience on a 10CC engine.
Kurt.
nomad
Curious that if the oil from the scroll seal doesn't get into the bell housing why did the early sprite's have so much trouble with clutch slip while racing. I assumed it was caused by an oiled clutch. Anybody know??
Kurt
Gerard
Kurt
The gearbox also uses a scroll seal in the front cover. They don't work that well, and I would guess thrashing a car around would slosh the oil around quite a bit, especially under hard braking. There no vacuum assist to help either.
nomad
Good point Gerard. The extension on the gear box would get oil to the clutch plate better than anything else!
Kurt.
I Bugeye oil leak help Spridgets 4
R Bugeye oil pressure line Spridgets 9
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
I Bugeye oil pan help Spridgets 3
I Bugeye dash pot oil level Spridgets 3
M What is the proper oil for Bugeye engne and transmission Spridgets 6
M Oil filter on Bugeye question Spridgets 4
P Bugeye Water/Oil Combo. Gauge? Spridgets 4
P Bugeye oil/water gauge? Spridgets 6
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
T Oil Pressure-Bugeye Sprite Spridgets 12
I oil/oil additives for stock Bugeye engine? Spridgets 10
E Bugeye Oil Pressure Gauge Spridgets 5
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
