TR2/3/3A Brake Lamp
Got_All_4
Just noticed that I have to push the brake pedal fairly hard to get the lights to come on. Is there a adjustment. I turned the big 7/8 nut in a bit and had no effect.
charleyf
There is no adjustment on this original switch. Sounds like you need a new switch.
TR3driver
Great Pumpkin - R.I.P
I agree, first symptom of a failing switch.
Just curious, do you use DOT5?
Dr_Mike
A related question: Is it possible to check the switch before installing it? ( Have a switch that came with the car, and am reluctant to fill the hydraulic system and then have to bleed it again if the switch is a dud.)
charleyf
If you are willing to find some way to put pressure into the intake of the switch ( air compressor) and see if you can get continuity across the terminals with an ohm meter.
I doubt that you would affect the pressure in the line much at all by removing a switch and immediately replacing it.
Geo Hahn
I agree, I have always been able to swap the switches w/o having to bleed the system.
Does anyone know... are the threads on these the same as on a VW pressure switch? I ask as there is a German-made version I am using on my VW that seems very durable. Costs a bit more but I think this is a place where a few more bucks are worth it.
TR3driver
Usually I get fluid running out rather than air going in, but it might depend on whether you have the residual pressure valve or not. To reduce the amount of fluid lost, I use a bar to hold the brake pedal slightly depressed.
IIRC the threads are at least compatible with NPT. I once used a switch from an old Ford pickup and it fit the threads.
Later I got frustrated with frequent failures, and mounted a mechanical switch on the pedal box.
Then the most recent time around, I built a simple bracket to mount the switch inside above the brake pedal.
Got_All_4
Got_All_4
Yes I am using DOT5. Why do u ask? I remember Randal installing the electrical switch. Sound like a quick fix. Maybe permanent too.
Geo Hahn
Yes I am using DOT5. Why do u ask?...
There has been discussion linking DOT 5 with premature switch failure.
https://www.britishcarforum.com/bcf...ot-5-brake-switch&highlight=brake+switch+moss
Half way down that thread I mention:
That's what they seem to be saying. I'll be in the test group on this one as I have DOT5 and the switch sold by Moss -- Intermotor brand p/n 51620, made in England.
Switch installed 9/9/2009, 87,853 miles. Now at 92,997. So far, so good.
I has now been 9 years and 15,000 miles and the switch is still okay. I do have a relay on that circuit which may help preserve the switch.
TR3driver
I wonder what makes the original switch not compatible with DOT5.
On the one I cut apart, it appeared that the diaphragm was a metal on metal seal with no O-ring or similar, and enough Dot 5 had crept through the joint to foul the contacts.
I don't know if DOT 3/4 doesn't creep as well (although I suspect that us the case), or if it doesn't foul contacts like DOT5 does.
Supposedly, there is also a Harley-Davidson switch that will fit and stand up to DOT5. But I haven't looked into that myself.
CJD
I think it is. However, much like when you change your engine oil to synthetic...if you have a bad seal the DOT5 will compound it.
My 63 year old TR2 switch is still ticking along on DOT 5 for 1-1/2 years and counting. My TR3 lost it’s switch immediately on the change to DOT5, but went fine for 6 years afterward.
Got_All_4
Got_All_4
It's probably been 6 years for mine. The problem could have been there longer and just didn't notice. I was backing into the garage at night with a big white box behind me and that's when I noticed there was no reflection. So the molecules are smaller in DOT 5?
Dr_Mike
I did not read the original article, but, if I am wildly optimistic, having a switch that has never seen DOT 3/4 might be a solution , easier than distilling something to get rid of impurities. I guess this shows there is a scientific background to our practical difficulties, but no real solution except to try it! I shall try, and frequently back up to a white object to make sure the lights work!. I shall also use LEDs
On to the next "problem"
thank you
TR3driver
FWIW, I have seen rapid failures with new switches that were never exposed to DOT 3/4 (unless the manufacturer did it).
Silicone oil does have a tendency to find it's way through gaps that other things won't go through; and spreads to cover the surface even when it has to oppose the force of gravity to do so. It will actually climb uphill! There has been some debate as to just how it does that; as shown by the article summary I referenced above.
Got_All_4
Got_All_4
The next time I went out for a ride the brake light did not work no matter how hard I pushed the pedal. Couple days later I puled the car into the working garage and it work as it is suppose to. Go figure. Anyway not trusting it so went to Summit Racing and bought a universal brake switch. Brain stormed it for a while and it turned out a lot like Randles. Works perfect.
C TR4/4A left brake lamp not lighting TR4A Triumph 4
D How to remove the brake lamp relay Austin Healey 9
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
weewillie brake pressure warning lamp Spridgets 12
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
