Bosch Coil question
JPSmit
Friends, today I installed a Bosch Blue Coil - just want to confirm that it has an internal ballast and that, therefore I was right in bypassing the external Ballast Resistor?
Seems to run OK on a short run at least.
thoughts?
PS Top Tip - if you reconnect the Coil BEFORE you start the engine it will start quicker.
nomad
JP, how well does the engine start if you DON'T reconnect the coil before you START the car?:rolleye:
Kurt
nomad
JP, you can check the resistance of the primary windings to see if you have the right coil. Hopefully some one who actually keeps track of stuff like that will chime in with the correct resistance readings!:friendly_wink:
Kurt
JPSmit
JPSmit
Kurt
my point exactly. :rolleyes:
Bayless
He probably doesn't know how long it would take yet.
John Kuzman
Seems to me that internally ballasted coils measure about 3 ohms on the primary side.
dklawson
Bosch Blue coils are considered "standard" or 12V coils. They will typically measure more than 3 Ohms, typically about 4 Ohms. Bosch Red coils are the ones typically used with ballast ignition wiring.
JPSmit
JPSmit
Interesting - I know that Jeff at Advanced Distributers swears by the Blue coils - and sells them though when we last talked he was having trouble getting stock. Apparently there is much conversation about getting a proper one - who knew I figured a coil was a coil was a coil,
https://www.ratwell.com/technical/BlueCoil.html
In other news I had a club BBQ today - was a rainy day (drizzle) so put the top up - got it running (with the coil connected! :grin:smile: only to find the wipers didn't work - so back in the garage it went.
I have an old Bosch Blue coil that has bounced from car to car. It just keeps working. It is probably 30 years old (actually says made in Germany ... not Brazil)
nomad
I have a car needing a coil and I have a Bosch Blue coil in with a pile of other used coil's. Now if I can just remember where that pile of coils are....:rolleyes2:
Kurt
JPSmit
JPSmit
quick update - elsewhere there is a post about the car hesitating when hot - took the car out for a couple hours driving yesterday and it performed flawlessly, so, early indicators are that the coil may have been the culprit (as some suggested) - certainly so far so good!
SaxMan
Been there. Done that. Part of my "anti-theft" protection when the car was parked outside was to disconnect the battery and the coil. Of course, like any alarm system, you have to deactivate it before you drive it.
Jer
thoughts?
To answer your original question : Yes you were correct in bypassing the ballast resistor, at least I have no ballast on my 67 & run a Bosch Blue with a "Jeff" distributor :smile:
Also thanks for the pointer on hooking up the coil before trying to start... good point lol
JPSmit
JPSmit
glad to help! I have actually kept the ballast resistor in place just in case - as the old coil has gone into the trunk spares bag - the resistor is bypassed of course.
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
7 I screwed up - Bosch VE pump. Other Cars 1
7 No more Bosch tools for me Restoration & Tools 4
A TR2/3/3A Bosch ruled the day Triumph 2
aeronca65t Spitfire Bosch distributor in Spitfire? Triumph 3
Z Bosch Fuel Distribution Unit TVR 5
Z Bosch Fuel Distribution Unit TVR 2
hondo402000 Bosch alternator conversion Triumph 3
DrEntropy Bosch Plat Plus NLA? Other Cars 6
SCguy Bosch Fog Light Cover! Triumph 1
SCguy Wedge TR8 Bosch Fog light covers Triumph 8
T On a positive note - new Bosch alternator rocks! Triumph 21
T Paul - did you change any wiring for the Bosch? Triumph 3
tomshobby Bosch alternator Triumph 30
Brosky TR6 Fiesta Bosch Bolt on TR6 Alternator Triumph 35
bmurphy7369 Bosch Blue Coils... for older OPUS systems? Jaguar 3
Woodie bosch spark plug wires Spridgets 5
rodesmg bosch sparkplug Spridgets 1
Got_All_4 HELP ON BOSCH 55 AMP ALTERNATOR CONVERSION Triumph 1
aeronca65t Bosch Graphics Other Cars 4
LastDeadLast Bosch Alternator Wiring Question Triumph 1
K Bosch Fuel Pump Problem Triumph 4
O 110-amp Bosch Alternator Upgrade MG 47
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
