body-rear
Sorry for this rather dumb question. A few months ago I got stuck in deep gravel and the weight of the car was pushing on the rear license plate. My question is, is there suppose to be an indention where the frame mounts to the body? It looks perfectly pushed in but I don't remember it being so. This is a BJ8 phase I with the plate attached to the body and not the bumper. (You should have seen the circus helping me get out of the gravel) /ubbthreads/images/graemlins/blush.gif.
Keoke
/ubbthreads/images/graemlins/savewave.gif TH;
Wait till you see the circus taking that dent out of the healey's but.--Keoke :angel
Not difficult to do TH its in the AL shroud and easily accessible from inside and outside.
AUSMHLY
Well guys, you have been answering my questions the last couple days, thank you. Maybe, I can offer some help here, if indeed you do have a dent, and you want it removed. I do PDR, paintless dent removal for a living.(it's like a circus, people watching me, when I work on someones car) To learn more about it, vist my web site, as I explain this type of service. www.dentfree.us Look in the yellow pages to find a dent guy near you. Sorry, I'm not in your area.
Keoke
TH you have a dent, but if it looks like a recess to allow the plate to set level- just leave it alone.---Keoke /ubbthreads/images/graemlins/smile.gif
John Loftus
[ QUOTE ]
Yes, but do I really have a dent or a recess to allow the plate to sit horizontal?
[/ QUOTE ]
Hi TH,
The front and rear shroud aluminum is relatively soft and is easy to dent. As Keoke says, there is no recess for the plate, the shape of the rear shroud near the plate mounting is a smooth convex shape. I would pull the license plate and bracket to look closely at the damage. The license plate light and wiring should be carefully examined too. You don't want to short the wiring, especially since it is not fused from the factory. I too, would probably just leave the dent for now since it is in an area that is not easily seen and save any repair for the next paint job.
Cheers,
John
Randy Harris
[ QUOTE ]
[/ QUOTE ]
Hey Roger - good to see you've landed here. This is just an "amen" for PDR and a plug for my bud, Roger. A few months ago I assigned him the (previously thought to be impossible) task of removing more than 40 (not a typo) door and body dings on my '68 E-Type. He removed virtually every single one. Now it looks looks like a completely different car at a fraction of the cost of a body shop. It looks so good I've put off the repaint indefinitely. The key is the right technician with the skills and the right can-do attitude. Sorry, can't help you with the ding on your Healey's butt. Maybe a ding remover can though.
Great to see you here Roger. Let's hit the road with our cars soon!!
Randy '66 BJ8, '68 E-Type OTS
tahoe healey
I was thinking of making a jig with bolts going through the frame mounting holes and slowly tighten to pull form the inside-out. Any thoughts?
Unless AUMSHLY wants to do it in MY driveway. I'd even remove the snow. Hey, do you ski? We do come down to for Golden Gate Healey events and rides. May be we'll talk.
Keoke
[ QUOTE ]
[/ QUOTE ] Yep TH, either go to GG Events and talk to Randy or LEAVE it ALONE! /ubbthreads/images/graemlins/yesnod.gif---Keoke /ubbthreads/images/graemlins/patriot.gif
Johnny
I've had some pretty good luck using a suction cup dent puller on sheet metal. Loosen body from frame, attach suction cup (one made for bodywork) and pull like H***. Might just work and won't damage body. May have to try in several places to get it to POP back out.
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
K TR2/3/3A What is the distance from the rear overider to the body....... Triumph 3
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
K TR2/3/3A 3A Rear body sag? Triumph 11
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
M TR2/3/3A TR3 Rear Body Damage Triumph 9
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
R Body Rear View Mirrors Austin Healey 3
TR6oldtimer TR6 TR6 rear body shims [under trunk] what is ok? Triumph 2
D TR6 lost body shell Triumph 1
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
