CJD
Air rises if it has no other way to expel. If the valve on the slave is open, then the weight of the fluid overcomes the desire for air to rise and the air is pushed out of the valve. Once the bubble is gone from the master, just opening the slave valve will allow fluid and air to be expelled.
I believe the slave bracket was mounted in both locations over the years. It will become obvious which side the bracket needs to go when you hold up the pushrod to your assembly.
