BJ8 Gear Shifting
AUSMHLY
64 BJ8
Little history. Always had some difficulty going into 2 gear. Clutch in, going from 1st to 2nd, most times it slides right in other times I need to pull and hold it till it slides in, which may take 5-10 seconds as I coast down the street till it goes in gear. This is when tranny oil is cold and when hot. A friend recommended a British mechanic he's heard of. The mechanic drove it thinks the 2 gear synchro needs to be replaced. Should take a week. I give him the tranny, he has it over a month, says he's having difficulty getting the OD back on. (Now I'm uncomfortable with his knowledge and skill). I finally get the tranny back, install to find I don't have a working OD now. Another mechanic tells me OD doesn't work because there's no pressure. The new mechanic (Super Nice Guy!) and I replace the pump which we find the prior mechanic damaged, most likely trying to get the OD on.
Engine was rebuilt including new clutch same time as the tranny was worked on. Now cars back together and I'm driving it with about 100 miles.
Shifting from 1st into 2nd is better... but now I have a new issue. Clutch is fully depressed, going from 1st to 2nd I hear the gears grind, it's not going in. I've had this happen 3rd to 2nd also. I'm making sure the clutch is fully depressed and I'm at the appropriate speed. It's an intermittent problem. Why the big concern? I don't want to damage 2nd gear, because I'm told replacement 2nd gears are not available.
Is it the synchro or the clutch?
Could the 1st mechanic (who evidently is not experienced with working on these transmissions) have damaged the synchro, or damaged something related to shifting into 2nd?
1st, 3rd, 4th and the OD have always worked problem free.
Thoughts?
AUSMHLY
AUSMHLY
Hi Bob, I appreciate your help with all these issues I'm having with the tranny/OD.
I believe the synchro came from Moss. Where do they get theirs?
The layshaft was not replaced. I asked the first guy who replaced the synchro to replace anything that needs replacement. He didn't comment on the condition of parts in the tranny when I picked it up, and therefore assumed only thing that was needed was the synchro. The second mechanic helped me R/R the OD pump, we didn't open up the tranny, we removed the pump from the bottom of the OD.
I can remove the top plate on the tranny and have look inside. Any benefit to that?
Only something obviously broken; in which case you'd have more than a synchro problem. Layshafts do wear, but if yours was OK or replaced at restoration yours should be OK. It really sounds like a synchro problem since 1st doesn't have a synchro and 3rd and 4th use the same one.
You could start by draining the oil, O/D too, and see if there's any chunks in it. A BJ8 has iron synchros and, of course, they'll be magnetic.
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
W Cam gear position BJ8 Austin Healey 11
wangdango BJ8 gear shift consol restoration... Austin Healey 9
B stuck in 4th gear bj8 Austin Healey 8
mdw BJ8 gear shift thread Austin Healey 7
pkmh BJ8 Idler Gear [Steering] Austin Healey 34
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
D BJ8 Overdrive Switch on gear leaver top Austin Healey 2
S Gear Grinding in my BJ8 Austin Healey 2
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
